Old 02-27-2005, 06:09 PM   #1
Harold Shepard
Prop valve question
I am currently changing over a 69 mdel truck to disk brakes. I had already bought new brake lines (great deal- $20 for the 6 metal lines in front) with the plans to use the praise dyno brake kit. A 71 parts truck landed in my lap and now I have switchd gears and am using the spindles etc for disks (too far gone to stop- new upper and lower ball joints, tie rods etc.) But now I have a problem and I'm sure some one has run into it. How are you modifing the prop valve from the 71-72 to work with the 69 brake line set-up? By the way this is a power brake truck. Any input is greatly appreciated.
Harold Shepard is offline   Reply With Quote
Old 02-27-2005, 06:37 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You should use the disc/drum master cylinder in addition to the proportioning valve. The line pressure is way higher on a disc caliper and the full potential of the discs will not be realized onless you do it all right.
Old 02-27-2005, 08:28 PM   #3
Harold Shepard
I was planning to use the 71-72 M/C (Bendix) but the stock lines are going to be a pain- I hate to bend them to crap as they are new. What do you suggest to connect the 69-70 stock steel lines to the 71-72 prop valve and M/C as the dist. valve and the prop valve are two different things and as such the steel line don't exactly match up and I don't want it to look jerry- rigged. Harold
Old 02-27-2005, 08:37 PM   #4
cableguy0
the best way would be to sell the lines you have and make new ones the disk brake lines for the front are of smaller diameter
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
