Old 02-28-2005, 01:19 PM   #1
soleeagle
soleeagle's Avatar
My buisy weekend
Well I got the lift on my burb this weekend. I put a 6 inch on it along with the 3/4 ton axles that I rebuilt with disc brakes all around. The only thing I need to do is get a steering stablizer and get the sway bar hooked up. The tires are 33 inches for now, they were just the only 8 lug wheels I had and I am planning on going with at least 36-38 inch this spring.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 02-28-2005, 01:22 PM   #2
soleeagle
soleeagle's Avatar
some more
Chuck
Old 02-28-2005, 01:31 PM   #3
hotrodhomi
hotrodhomi's Avatar
Are all those blockes under your leafs safe? I'm not picking on you, just asking. It seams like it could fold right over with any force. It looks good though.
hotrodhomi is offline   Reply With Quote
Old 03-01-2005, 01:01 AM   #4
Esteban86K5
Esteban86K5's Avatar
No that is definataly not safe. Witha little axlewrap, you'll spit those right out. I would suggest looking into a shackle flip for the rear and only running the 2"blocks.
Be American Buy American
My Pics
Esteban86K5 is offline   Reply With Quote
Old 02-28-2005, 07:54 PM   #5
jermasaurus
jermasaurus's Avatar
I wish I had some jack stands like the ones in your first post.
jermasaurus is offline   Reply With Quote
Old 02-28-2005, 08:37 PM   #6
low 84
low 84's Avatar
looks great man. i'll be doing a similar swap in the next couple weeks.
couple questions, first where did you get those jackstands? those things are sweet. and also, on the rear breaklines did you find a bracket to secure the other end of the rubber line to the axle and then weld it on the axle tube? i'm looking for a little bracket like i have seen others use but i dont' know what to get it off of
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-01-2005, 12:05 AM   #7
soleeagle
soleeagle's Avatar
Thanks everyone.
couple questions, first where did you get those jackstands?I made the stands at work, they adjust to 4 different heights at 3 inches at a time. They are sweet and very handy. those things are sweet. and also, on the rear breaklines did you find a bracket to secure the other end of the rubber line to the axle and then weld it on the axle tube? I havent yet but I am planning on doing so soon, I still have a few things to do in order to have the lift completed.i'm looking for a little bracket like i have seen others use but i dont' know what to get it off of
Chuck
Old 03-01-2005, 05:37 PM   #8
RANDY COX
RANDY COX's Avatar
Iv'e been running mine with 4" blocks in the rear and no trouble at all.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 03-01-2005, 05:51 PM   #9
Prerunner1982
Prerunner1982's Avatar
Randy if you will notice he has 2...2" blocks.. other than that... looks sweet..
Prerunner1982 is offline   Reply With Quote
Old 03-02-2005, 12:15 AM   #10
soleeagle
soleeagle's Avatar
There are not 2 2" blocks in there. They are 1 4" block. The pic just makes it look that way. I would never stack blocks up to get more lift. I have had 4" blocks in my truck for almost 2 years now and never had a problem yet. I will be looking into a shackle flip in the future.
Chuck
Old 03-02-2005, 03:52 AM   #11
Esteban86K5
Nothing wrong with blocks. I ran them for a few years also with no problems. It just looks like they were stacked. And that would be
The shackle flip is more expensive but a better alternative then the blocks. You won't get the axle wrap as you would with the blocks.
Project looks good.
My Pics
Old 03-02-2005, 09:37 PM   #12
Prerunner1982
Old 03-01-2005, 06:05 PM   #13
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
So would a shackle kit raise the rear? Wouldnt it be better than blocks? Ive never really messed with any of these things yet.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-01-2005, 06:13 PM   #14
Prerunner1982
yes a shackle flip can raise the rear about 4", ORD offers 2.5" and 4" lift brackets.. and yes it is much better than blocks..you can use your stock springs (unless you want more than 4" lift) so you can keep a softer ride and some flex...
