Old 02-28-2005, 11:29 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Front end possibilities?
I have a 70 stepside, but it has disc front brakes. I'm going to replace a lot of the front end parts when I do my 4/6 drop. I wanting to know what application to look at when I look for parts. I've been looking at 71-72 ball joints, tie rod ends, etc. I don't know what else the front end could be off of. I contacted the last 2 PO's and they didn't know what the front end came from.
I'd appreciate the help
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 02-28-2005, 11:42 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
it could be anything from 71 up to 87!
If you can post pics of the rotor and the caliper...and maybe the A-arms.,...some one might be able to set you in the right direction.
Old 03-01-2005, 12:53 AM   #3
farside847
farside847's Avatar
Hell, it might not even be chevy. Ive heard of some frankenstein front ends put together from ford and dodge parts.
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-22-2005, 04:52 PM   #4
5150
C10 Club Tennessee
5150's Avatar
I went to see my truck and took these pics today I don't know if you guys can help me determine a little better now or what?
Bryan
www.gmtruckshow.com
Old 03-22-2005, 08:56 PM   #5
5150
C10 Club Tennessee
5150's Avatar
ttt
Bryan
www.gmtruckshow.com
Old 03-22-2005, 10:42 PM   #6
4tiresngas
An American Soldier
4tiresngas's Avatar
Okay, I'm definitely not an expert, but I'm going through this same issue with my 69. I spoke with someone at Early Classics Eterprises. He explained that if you measure the opening on the spindle where the tierod connects and it is 5/8" it is a 71 or 72. I think he said 73 and up are 3/4"...don't quote me.
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 03-23-2005, 02:40 AM   #7
5150
C10 Club Tennessee
5150's Avatar
Can anybodyelse back this theory up? I'm wanting to go ahead and by my front end parts before the 4 inch drop while my wife is in a giving mood.
Bryan
www.gmtruckshow.com
Old 03-23-2005, 08:52 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You have a bastard front end.
The disc brakes, control arms, etc, are obviously GM truck. Your crossmember is original drum brake truck unit. The way to tell is that your brake hoses come off the calipers and go to the backside of the crossmember. Factory disc brake crossmembers had the brake hoses routed to the front side.
That's a sure sign someone has updated the brakes and left the original crossmember.
If you have screw in metal control arm bushings, it's a 71-72.
If you have rubber control arm bushings, it's 73 and newer.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-23-2005, 08:55 AM   #9
Suicide-D
Location: Katy, TX...but the love of my life resides in Dublin,OH.
Judging from the brake hose banjo fitting...looks like a 71 to me.
Suicide-D is offline   Reply With Quote
Old 03-23-2005, 08:21 PM   #10
5150
C10 Club Tennessee
5150's Avatar
So if I wanted to by both ball joints and outer tie rod ends what would you guys recommend I get them for?
Or am I going to have to wait till I get the truck back and pull everything off of it and bring it to the parts store to match.
Bryan
www.gmtruckshow.com
Old 03-23-2005, 08:44 PM   #11
Tx Firefighter
Here's what I would do myself.
71-72 and 73 and newer tie rod ends use different threads and adjuster sleeves. I'd buy whatever fits my current adjuster sleeves.
I'd remove the old outer tie rod end and take it to the parts store. Find out if it matches up to a 71-2 or 73 and newer tie rod end. Then buy my stuff for that year. You're buying drop spindles and ball joints anyway. All balljoints interchange in the control arms. If you buy 4 new ball joint and a set of dropped spindles anyway, it doesn't really matter. But, if you can use the proper tie rod ends, you save the added expense of fooling with new adjuster sleeves and all of the center steering linkage stuff.
Old 03-24-2005, 12:57 AM   #12
5150
C10 Club Tennessee
5150's Avatar
Yes, I've already bought McGauhey's 2 1/2 drop spindles. I'll just wait and take the tie rod end off and bring it to the parts store.
thanks Kevin
Bryan
www.gmtruckshow.com
