Old 03-01-2005, 01:17 AM   #1
krue
Designated A-hole!
krue's Avatar
Top questions
I have two different tops for my blazer. The one that is on it has a lip that is bolted to the bed rail. The spare (given to me by ken betz ) mounts with bolts thru the bed into nuts built into the top. I am guessing the first is single wall and the second is double wall?
Two tops, one rear hatch. Will it work on both tops?
Which top is better (assuming they are in comparable shape)?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-01-2005, 01:36 AM   #2
saulgoode
saulgoode's Avatar
You are right, bolts from top single wall, bolts from bottom double. Both tops being equal I'd rather have a single, they are lighter and have the inside cargo lights, double doesn't. The hatch is the same. Plus the sinle is easier to take off if you have the side panels, you would have to take those off to get to the bolts on a double. But if none of that maters to you, you could run the double and sell the single, they are a little more desirable. Hope this helps.
Saulgoode
saulgoode is offline   Reply With Quote
Old 03-01-2005, 05:06 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Originally Posted by saulgoode
Plus the single is easier to take off if you have the side panels, you would have to take those off to get to the bolts on a double.
Saulgoode
I'm thinking about studding mine for this very reason, still trying to work
out all the details, but if I stud all of the middle bolts and just use the
1's w/ the brackets near the tailgate and the ones on the upper portion
of the windsheild frame will it be fastened secure enough, any opinions.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-01-2005, 05:28 PM   #4
vtblazer
vtblazer's Avatar
Studs
That's a good idea but you'd have to be REAL careful taking it on and off.
I think using the bolt hole/mount just behind each door along with the other's you mentioned would be a "minimum".
vtblazer is offline   Reply With Quote
Old 03-03-2005, 06:01 PM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I WAS GOING TO USE A SLIGHTLY SMALLER STUD SIZE AND COVER IT WITH
SOME CLEAR TUBING, LIKE FOR A FISHY AQUARIUM AIR THINGY, THEY MAKE
THAT CLEAR TUBING AS THICK AS 1/8" IN THE SIZE NEED, PRETTY SOFT.
Old 03-01-2005, 09:14 AM   #6
Huck
Huck's Avatar
The double wall has a seam right down the middle which often opens over time. They also tend to warp on the top going from covex /\ to concave\/ which looks kaka.
Huck is offline   Reply With Quote
Old 03-01-2005, 01:14 PM   #7
krue
Designated A-hole!
krue's Avatar
Thanks guys.
www.daveramsey.com
Old 03-01-2005, 01:38 PM   #8
Trifelynn
Trifelynn's Avatar
Here is a top question...I appoligize Krue, don't mean to steal your thread, but it goes right along with your thread...
Is it easy/possible to repair tops? I have some cracks/knicks/chunks in my top...
I assume that it is possible, but I suppose I should make sure..
anyone had their top repaired?
I have a single wall, and would like to keep it, if I can fix it..
thanks
Lenny
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 03-01-2005, 03:07 PM   #9
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Since the tops are fiberglass, you can repair damage. If you remember Diane (1970Blazin), she had her top repaired by a guy who works in fiberglass. Usually, guys who do boat repairs can make the repairs to the tops.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-01-2005, 03:25 PM   #10
krue
Designated A-hole!
krue's Avatar
That's definitely good to know. Mine may be structurally sound, but they look like poop!
www.daveramsey.com
Old 03-01-2005, 05:54 PM   #11
Huck
Huck's Avatar
Blazer tubs are far from solid even when like new. The factory manual recommends shimming body mounts to get proper alignment of doors etc. I think you will sacrafice body rigidity when you stud a bunch of the top side mounting bolts and may wind up seeing cracks in the 30 year old fiberglass top. My tendancy is to "do or do not, there is no try"----a little green guy used that line in Star Wars and it kind of works here!hehehehe
