Old 03-03-2005, 09:24 PM   #1
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
Question 86 CAB 75 front fenders
What problems will i run into trying to do this all the indications I got were that the CAB and the doors are basically the same
pedrofixlater is offline   Reply With Quote
Old 03-03-2005, 09:33 PM   #2
smokinn
smokinn's Avatar
75 fenders wont fit on a 86 cab.
smokinn is offline   Reply With Quote
Old 03-03-2005, 09:40 PM   #3
pedrofixlater
75 STEPSIDE
will i be able to use the 75 radiator support with 81-87 fenders
Old 03-03-2005, 11:10 PM   #4
smokinn
smokinn's Avatar
nope
Old 03-03-2005, 11:16 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I have no personal experience with it, but I thought several people here had reported that it will work in the past. I though they were basically the same. The wipers are different, though, hidden under the hood on one and not on the other.
You might try a search and see what you can find.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-04-2005, 12:03 AM   #6
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
What exactly are you trying to do? If you want to use the 86 cab and the 75 front clip, you can do that without any problems. You will need to use the wiper linkage (GM called them wiper transmissions) for the clip you are matching. If you are trying to mix and match 75-80 fenders on an 81-87 front clip, that won't work. You have to use the radiator support, fenders and hood as a set.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 03-04-2005, 12:28 AM   #7
Slonaker
Slonaker's Avatar
http://207.44.196.117/vboard/showthread.php3?t=143961
It sounds like he just wants to replace the cab on his '75 with one from an '86. That should not be any problem if he does what you said.
Slonaker
Stock '01 Silverado
