03-04-2005, 07:58 PM | #1 |
4L60E aluminum driveshaft fitment
Sorry if this has been answered a bazillion times, guys....I wish the search feature was working.....
I have sitting in the bed of my 71 Cheyenne a 99 5.7L and 4L60E from a 'burb. I also have the nice aluminum driveshaft from that same vehicle. Since the 4L is ~2" longer than my TH350, I will have to have my driveshaft shortened anyways. Is there a way to use the one piece aluminum shaft? I appears as though there would need to be some serious surgery to the center mount X-member for this to work.....anyone done this? Would I also have to lower the tranny mounting point to get a better driveshaft angle? Thanks, Tim
1972 Suburban C20 454/TH700R4, eaton-corporate 4.10 (looking for 3.7) Sold: 71 Cheyenne 20 Installed a 99 5.7L L31/4L60E from Suburban 1500 (2005) |
03-04-2005, 09:08 PM | #2 |
I may be missing something but being made of aluminum doesn't enter in to it. Most of us run one piece steel driveshafts on SWB trucks--the two piece is nothing but trouble. BTW--But I'll give you $5 for that driveshaft!
Stepsides look like real trucks! Smitty |
03-04-2005, 10:41 PM | #3 |
This is a LWB 3/4 ton Cheyenne 20 fleetside. As I look at the driveshaft from under the truck, the one piece looks as though it would hit the X-member where the center bearing is mounted. Is there a work around to that problem? Fabbing a new X-member isn't a problem, but maybe there is an easier way?
03-05-2005, 03:31 PM | #4 |
Somebody must have done this......
Pretty please.....or am I on my own with this one?
03-05-2005, 04:02 PM | #5 |
Sorry, I've never tried putting a one-piece in a long bed--but this will bump you up........
But if I was determined to use it, I'd modify the existing crossmember--or you could just stick it in and drive very slowly over uneven ground until you built some confidence it wasn't going to hit????
03-05-2005, 05:18 PM | #6 |
Well....on closer inspection, the aluminum shaft has some dings...from the forklift at the yard I suspect.....I will just have the original shortened......
