Old 03-06-2005, 07:41 AM   #1
willow72
willow72's Avatar
horn relay
my horn dont work and i am getting a battery drain can i get a horn relay at part store too fit our trucks or do i need to contact one of our venders for it?
willow72 is offline   Reply With Quote
Old 03-06-2005, 08:00 AM   #2
JimKshortstep4x4
Talking
Horn relays don't cause a lot of problems. Does it click when you push the horn button?
Try unplugging it to see if the drain goes away.
Jim
Old 03-06-2005, 08:18 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Jim's right about the horn relay. They are usualy trouble free.
However, if you ever do need one, they are a common parts store item.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-06-2005, 09:40 PM   #4
Sonny
Active Member
My aftermarket steering wheel adapter is off just enough where the plunger touches the side and keeps the horn contact made. I didn't notice this until I changed out steering columns. The PO had cut the horn wire and unplugged the horn. I didn't find the horn relay was constantly on with new column (I never connected the horn back up) until I killed a battery and alternator. You would figure that the horn circuit between the horn button and relay would be on a fuse...
Sonny is offline   Reply With Quote
