Old 03-06-2005, 09:47 AM   #1
modifiedGMC
Gmc Factory Gauges For Sale
I have the original factory speedometer and fuel gauge I took out of my GMC when I changed to Camaro gauges. Both faces look like new and are perfect but the two screws have surface rust on them. The speedometer needle has some fading in the center and the fuel needle looks perfect.They work fine I just don't want to lay them around and them get messed up. If anyone is interested make an offer plus shipping which won't be over $4 for both gauges shipped priority.
If it don't fit, force it,...If it still don't fit , modify it 'till it does fit !!!
modifiedGMC is offline   Reply With Quote
Old 03-06-2005, 12:46 PM   #2
REPO1
Shortbox wanna-be.
REPO1's Avatar
Do you have any pics of your camaro guages installed? I am planning this for the tach, and wondered what it would look like with the speedo installed as well.
Thanks!
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 03-06-2005, 09:00 PM   #3
modifiedGMC
here's three pics of it before and after notice I had indicator lights and had to relocate a couple of them but it all turned out good.
Here it is before
Here it is after I put the gauges in.
Here it is installed in the truck
Old 03-06-2005, 09:46 PM   #4
dmec
dmec's Avatar
does the camaro fuel gauge register correctly with the truck sending unit?
dmec is offline   Reply With Quote
Old 03-07-2005, 06:34 PM   #5
modifiedGMC
yes BUT when mounting the camaro gauge you have to drill one hole in the truck housing AND the conections are reversed on the camaro gauge ( I had to split my circuit board and reverse the two connections) But other than those two mods it fit like a glove. The speedometer bolted right in no mods other than I had to change and use a camaro cable because it slips on and the truck screwed on. It is two very simple modifications that look good.
