Old 03-06-2005, 09:41 PM   #1
72longbed
72longbed's Avatar
Question Help with Brake Shoes Please??
I need to replace the shoes (and just about every damn think else inside the drums) on a 1971 HO72 8 lug Rear axle. This is the HO72 that has the pinion tensioning bolt on the side of the center section.
So I go to the Advance Auto Parts and ask for a set of shoes and no less than four (4) different sizes come up in their computer for that year K20.
Does anybody know what the correct size shoe for a 1971 HO72 is?? I did bring with me the completely rusted relics that were on it, but the guy tends to think somebody put the wrong shoes on it at one time.
Also would be super helpful if someone could direct me to a good picture resource for the HO72 drum to drum?
Thanks,
72longbed
72longbed is offline   Reply With Quote
Old 03-07-2005, 08:05 PM   #2
ckhd
ckhd's Avatar
I'll bet good money it's a HO52 - nearly the same as an HO72, but not quite has heavy duty.
'71 K20, it should be 12" x 2". Orig GM part no. looks to be 3933981.
If it was an HO72, it would have 13" brakes.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 03-07-2005, 08:07 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I think the dana 60s had odd ball sized shoes. As was said should be 12x2 that's what's on my 71 K20.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 03-07-2005, 08:09 PM   #4
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
They should be 12" by 2 3/4" wide for the HO52. That's what they are on my truck.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 03-07-2005, 08:15 PM   #5
ckhd
ckhd's Avatar
the four wheel drive rear drums were different than the two wheel drive. '71 two wheel drives had 11" x 2 3/4", four wheel drive had 12" x 2"
Not sure on '70, don't have as much info on them, but it looks like it should also be the same.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Old 03-07-2005, 09:36 PM   #6
72longbed
72longbed's Avatar
Exclamation Found Out Size Today!
I went to my buddy with the drum cutting machine and asked him what size brake shoes went inside the drums he had just cut for me. He took out his trusty tape measure and, sure enough, they are 2" x 12" that fit those drums.
BTW, its definitely an HO72 as evidenced by the 8 Lug hubs and the pinion adjusting bolt on the center chunk. The Detroit Locker from the factory also says its an HO72.
Did I read that somebody makes a disk brake conversion for these HO72's??
Or did I read that the kits for a 14 Bolt Full Floater also work on the HO72??
Anubody know the answer??
Thanks,
72longbed
Old 03-08-2005, 08:08 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I believe the disc brake people are called Blackbird. There's a member here who is mixed up with them. Their website lists rear disc kits for all these old rearends.
Edit- I found their site.
click HERE
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
