What Hump?
305/350 How to identify?
Just like the question says, I know the serial number show that but what am I looking for, and how do you tell the difference between a 2 bolt and 4 bolt? I want to make sure the engine I just had dropped in is what I asked for.
Sorry to ask but the search has been disabled. Thanks Tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
Right turn Clyde
Well if its a 305 don't worry about the 4 bolt mains, there aren't any. Unless someone has a prototype block or something. As for the 350 its really hard to say without dropping the oil pan. Only thing I can thing of is the date and suffix code. Depending on what that decodes to it may be a little easier to guess if its a 4 bolt main.
What are the codes you have now?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
no way to tell if you've got a 4 bolt without pulling the pan.
Yeah........................you gotta pull the pan.
Too many "old wive's tails" about 010 blocks floating around. |
depending on who you talk to, an "010" block can be 2 different things. to most serious engine builders, "010" refers to the casting marks under the timing chain cover, which is said to be information about the composition of the block casting. to many novices, any engine that carries the casting number "3970010" is an "010" block. nothing special about a 3970010 block, just your basic 68-85 302/327/350 block.
Project 2 Resume
Actually many years ago I had a 77 Monza Spyder with a 305 and 4 bolt mains. I don't remember if it was the original motor or not because I yanked it out almost immediately. The car was from Canada and stock.
010's were from 69-80, which the older years are supposed to have a higher nickel and tin content. I have them in both versions (2 bolt and 4 bolt). well actually one of the 2 bolts I presently have, I splayed to 4 bolts. Like said earlier, you have to pull the pan. btw, my 84 350 4 bolt has 010 cast in the timing chain area. however, i forget it's casting number.
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
#7 | |
Project 2 Resume
I'm sure anything is possible and nothing surprises me with dates and castings anymore. I've built many and personally, I haven't come across a passenger side dipsticked, 010 stamped bellhousing block. Maybe one I will.
I've also only seen one factory 4 bolt 305 in my life, which I owned, while others claim they don't exist. Back then no internet, no pics, I didn't care if it was special or not, it was coming out for a destroked 400 (377).
my gas saver
don`t forget the newer blocks. it may have 5.0 or 5.7 stamped back there too. you can`t mistake those.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
