Old 03-08-2005, 05:25 PM   #1
boraxman
Keepin an eye out
boraxman's Avatar
supertrac bar kit or adj. panhard bar....
on a 5" coil rear drop?, '70 C-10.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-08-2005, 05:34 PM   #2
XXL
Seņor Member
XXL's Avatar
For coil drop, either will work. Since the suspension isn't making drastic height changes like on an air bag system, once you dial in the setting, you're pretty much set.
XXL is offline   Reply With Quote
Old 03-09-2005, 12:37 PM   #3
UP GRADE
one set closer
UP GRADE's Avatar
will a adj. panhand bar work with a 6 inch coil drop.
UP GRADE is offline   Reply With Quote
Old 03-09-2005, 04:37 PM   #4
Frank_Zeller
Frank_Zeller's Avatar
If you only do the panhand bar the mount point will be to high on the rearend. This may cause the rear to go from side to side as it travels up and down. The ECE kit mounts the pivot point on the passengers side rearend mount.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 03-09-2005, 05:42 PM   #5
XXL
Seņor Member
XXL's Avatar
Except that coil ride height isn't too variable... maybe 3" of excursion/compression (unloaded) at best. So there's really not much side-to-side issue to speak of. Having said that, longer is always better (and I'm still talking Panhard bars).
Old 03-11-2005, 08:24 PM   #6
SCOTI
SCOTI's Avatar
Originally Posted by XXL
.... longer is always better (and I'm still talking Panhard bars).
Sure you are .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
