03-10-2005, 11:54 AM | #1 |
lone grey wire on tilt column
Hey all I am installing a truck tilt. I have the connector pluged in but there is a long grey wire with a single plug on it. Is this for power for something? Or maybe a ground?
Thanks DAve
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
03-10-2005, 12:00 PM | #2 |
Resident Curmudgeon
shift indicator light. Plug into the cluster feed spade. This will allow it to dim and brighten along with cluster.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-10-2005, 12:07 PM | #3 |
More Cowbell....
Sweet. G-Man69 and I both have that wire (unhooked) and were wondering what it was for. Just never thought enough about it to ask.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
03-10-2005, 01:46 PM | #4 |
Thanks Jeff you are a wealth of knowledge...
and other stuff...
03-10-2005, 01:53 PM | #5 | |
Resident Curmudgeon
