Old 03-10-2005, 01:16 PM   #1
aitch
aitch's Avatar
Water temp gage question
I plan to install my Camero tach soon in my bezel. While I have it apart,
I'm wanting to install a water temperature gage in the blank vacuum gage spot.
What gage will work best for this? Anyone done this? Instructions? Pictures? Suggestions?
Thanks,
Aitch
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
aitch is offline   Reply With Quote
Old 03-10-2005, 07:32 PM   #2
aitch
aitch's Avatar
ttt
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
Old 03-10-2005, 07:58 PM   #3
724wdcopper
graphic designer
724wdcopper's Avatar
so you're gonna have 2 water temp gauges? there should already be one on the left side.
724wdcopper is offline   Reply With Quote
Old 03-10-2005, 10:41 PM   #4
aitch
aitch's Avatar
I admit there is a lot I don't know but I don't think my temp gage on
the left actually shows what temperature I'm running. Mine registers C - H.
What does the factory gage actually sense, is it water temp? Again, I don't know where the sensor is placed.
If the C - H gage is a good indicator of engine temperature then I don't need anything else. Thanks
aitch
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
Old 03-11-2005, 02:20 AM   #5
724wdcopper
graphic designer
aitch
that one's water temp. sensor should be at the front of the intake manifold or on the head between the exhaust pipes. C=cold h=hot usually if it's in the middle, you're good. lean towards the h, keep an eye on it.
Old 03-10-2005, 10:49 PM   #6
shifty
Questionable
shifty's Avatar
I think someone makes an analog clock that will fit in the hole. I know I've seen it somewhere, but I can't remember where
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-11-2005, 09:31 AM   #7
aitch
aitch's Avatar
Thanks all, the mechanic that did the install on my fresh 383 said that if it was his, he'd get a water temp gage. I'll ask him about it this weekend.
69 GMC 3/4 ton LWB
383 TH400 Dana 60
'84 300ZX
'79 Nova (for sale)
