03-10-2005, 11:07 PM | #1 |
Shortbox wanna-be.
Motor Mount Question
Can someone tell me for sure if the motor mount towers are the same or different between the big block and the small block?
Also can someone post a picture of an actual BB motor mount itself? And lastly, if someone had a part number for NAPA to purchase the motor mount for a big block that would be awesome. Thanks! Reid
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
03-11-2005, 01:30 AM | #2 |
its all about the +6 inches
no pics here...but they are DEFINATLY different.
There are 2 different big block towers... the 68 - 71...diret cheap, but the motor mounts are expensive...the 72 style, the towers are expensive...but the motor mounts are cheap. |
03-11-2005, 01:38 AM | #3 |
Shortbox wanna-be.
Hmmmm that sucks then. I had a pair of small block ones laying around and cleaned them & painted them already. I took a quick look at the ones already in my '70 (402) and thought they looked the same. Are the small block ones just taller? What is the noticable difference?
Thanks for the help! |
03-11-2005, 01:41 AM | #4 |
I believe the BB towers are notched for the exhaust manifold. I used SB towers in my '68 when I put the 396 in it. I don't remember if I modified them or what. I used headers. Oh yea... BB towers have a huge hole in them for the bolt to the mount.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
03-11-2005, 01:45 AM | #5 |
Shortbox wanna-be.
Does anyone have an actual picture of the rubber motor mount itself? (BB)
03-11-2005, 02:28 AM | #6 |
Ebay auction for the towers...
http://cgi.ebay.com/ebaymotors/ws/eB...category=34202
03-11-2005, 08:38 AM | #7 |
Watch out for your cornhole !
Read the article I did in the FAQ section on cheap big block mounts. It shows how to use the cheap early big block stands with small block rubbers.
I've been through this frustration before a few times, so I posted pictures and descriptions. Using the article, you can get big block mounts pretty cheap.
03-11-2005, 09:49 AM | #8 |
BB rubber mount GM NOS part number 3997595 for 68-71...there ya go. Thats what was listed when I saw it posted somewhere. I couldn't find the number in my parts book..but thats not so unusual as numbers changed over the years. My parts book lists the numbers 3986604 as mounting, engine -front, upper for engine front 68-71 396/400.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
03-11-2005, 09:56 AM | #9 | |
Shortbox wanna-be.
Excellent! Thats what I need. I already have a set of small and a set of the big stands, but I hadn't realized they were different, as the BB stands are still in the old frame with the motor on them. (couldn't see the difference) Now all I need is to find a new pair of the rubber mounts. |
03-11-2005, 10:04 AM | #10 |
Had this pic too..I think it correct rubber mounts on the brackets...I had it named BB.
03-11-2005, 03:57 PM | #11 |
heres some 67-71 with the correct rubber.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay |
03-11-2005, 08:59 AM | #12 |
Here are the ones listed in the auction...thesae shouldn't get too much $$
Misadvertised as 67 - 72...they are actually 68 - 71 |
03-12-2005, 05:59 PM | #13 |
PROJECT 7DEUCE
I have my 454 on sb stands and the fit is pretty good.. I did however just score a set of bb mount so I will be trading up here soon.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
