Old 06-03-2002, 09:17 PM   #1
JHickson6
I Love This Stuff!
JHickson6's Avatar
Question C10 Body Drop
Has anyone out there done a full body drop to their C10. I want to do give my 67 C10 a full drop with air ride suspension and a rear 4 link setup. What kind of rear C notch will I need? Big one (8" notch) or one that bolts up to the frame. Can you body drop a C10 without cutting the box? In the front do I have to scrap the inner fender wells? Any info would help alot.
Thank You
JHickson6
JHickson6 is offline   Reply With Quote
Old 06-03-2002, 09:54 PM   #2
SCOTI
SCOTI's Avatar
You can use stock trailing arms w/the bags in custom mounts (instead of factory location) or spend more for the 4-link(which has more adjustability). The c-notch will depend on how much of a body drop you do(a big b.drop won't require as much of a notch). The bedfloor can either be raised or sectioned & the front fenderwells will either need to be tossed or modified extensively. Hope this helps.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-07-2002, 08:57 AM   #3
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Jegs has got 4-links at $146 w/o the rod ends. That's another $60 but it's still pretty cheap.
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 06-11-2002, 03:34 PM   #4
SoCal68
I'm currently finishing a custom rear 4, or should say 5 link suspension for my C10 shortbed. With airbags and an estmated rear suspension travel of 9-10 inches, a longer rear setup is more desirable to eliminate a sharp degree of rear axle arc. As for a notch, a bolt in kit will not provide enough clearance. I stepped the rear of the frame and continued out the back without ever dropping back down. This will provide the cage for my fuel cell. I am body dropping the truck 3 inches with 20 inch rims in the front and 22 inch rims in back. It will lay rockers when done! I won't be running inner fenders. The hood and fenders will be welded together and tilt forward. I have many photos and will try to get some posted.
SoCal68 is offline   Reply With Quote
Old 06-11-2002, 04:05 PM   #5
JHickson6
I Love This Stuff!
JHickson6's Avatar
Thank you that clears alot of my questions up!!!
You guys never dissapoint me!!
Can't wait to see the all the pics! Do you have any from the 5 link install?
Thanks Again
JHickson
Old 06-12-2002, 11:18 PM   #6
PushinPebbles
My dad's 68
PushinPebbles's Avatar
I'm gonna B-drop mine this winter........3-3 1/2 in................wish me luck....................any pics would help.......................Jack
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 01-18-2003, 03:13 PM   #7
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
Cool I bodydropped my 62 2.5"
If you want to see pics and info check out my site. It's under my truck page.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
