Old 03-13-2005, 12:07 AM   #1
87_Blazer
Getcha' Pull!!!
87_Blazer's Avatar
'Burb Buckets In A Blazer
Will the factory buckets from a Burb bolt right in to my Blazer or will it take some modifying?? I am just curious as to the floorpan design and layout.
87_Blazer is offline   Reply With Quote
Old 03-13-2005, 01:21 AM   #2
k5mike
they will not fit with out mods....I did it with a pair of aftermarket seats from a burb......good luck.......
k5mike is offline   Reply With Quote
Old 03-14-2005, 02:14 PM   #3
loblazer
loblazer's Avatar
I was thinking of the same for my 80 blazer. I was wondering if I could get the seat off and weld it onto my seat frame?
loblazer is offline   Reply With Quote
Old 03-14-2005, 02:48 PM   #4
Jonboy
Slots go on anything!
You can drill new holes and bolt the Sub seats to the Blazer tracks. I put 87 Sub buckets in my 75 that way. Much nicer seat.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 03-15-2005, 10:39 PM   #5
loblazer
loblazer's Avatar
I was thinking of going to 3rd gen seats, 94 to 97 maybe? Tahoe or Yukon?
Old 03-15-2005, 11:19 PM   #6
cochino12
It followed me home?
cochino12's Avatar
I put a 60/40 from a 99 chevy in mine
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 03-16-2005, 02:25 AM   #7
kevinr1970
In my '81 2wd Blazer I have a pair of what I was told were late model Tahoe electric buckets. They are dark red clothe. They aren't bolted down or anything, just sort of laying there.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 03-18-2005, 01:50 PM   #8
loblazer
loblazer's Avatar
Well I hope you aren't driving it !!!!!!!!!!
Old 03-21-2005, 01:43 PM   #9
beaterC10
If you are trying to install Burb buckets in Blazer, you can, using the Blazer tracks. I have a set of buckets from an 86 Blazer that I am installing in a pu with the Burb brackets. The Burb brackets were a bolt on to my Blazer seats. No modification was needed to the brackets or buckets.
beaterC10 is offline   Reply With Quote
