03-14-2005, 11:14 PM | #1 |
Embrace the Redneck
WTB or trade: drive shaft!
I'm in need of a drive shaft for a 68 w/ a short tail 3 speed coarse spline output shaft.
Measurements of the current drive shaft: from end of fnt yolk to center of rear u-joint: 77.5" from center of fnt u-joint to center fo rear u-joint: 72.75" (someone correct me if i'm wrong) this one is a 2 piece and is useless to me and if anyone wants it it's up for grabs or trade. and what i think i need is about 4 to 7" longer (I'm really not sure) I'd really like a one piece shaft but a dual will due. Imput anyone thanks sswj
'01 Camaro Son, you just can't get there from here... Last edited by whitesswj; 03-14-2005 at 11:34 PM. |
03-14-2005, 11:21 PM | #2 |
Is yours a short bed? I just pulled apart a 68 6cyl 3spd longbed. It has the big spline input.
03-14-2005, 11:29 PM | #3 |
Embrace the Redneck
you know that's a good detail that i failed to menton. I have a LWB pickup.
one question. is the front drive shaft the olny part i need if i stick with a 2 piece? mind you i need a shaft for a V8 3 speed short shaft thanks sswj
'01 Camaro Son, you just can't get there from here... |
03-14-2005, 11:33 PM | #4 |
I have exactly what you need here. A 2 piece shaft,out of a 48k 68 C/10 6cyl 3spd.longbed $50 shipped. I will have to take it apart so it can be shipped,Let me know,Erick
03-14-2005, 11:37 PM | #5 |
Embrace the Redneck
are you sure it's just right? the inline's were set backward in the compartment more than the V8 so the shafts were shorter. I just moved the tranny up into the V8 position. are you sure?
03-14-2005, 11:38 PM | #6 |
I will get you measurements of it tommorow,To be sure.. Is that o.k.?
03-17-2005, 02:03 AM | #7 | |
Embrace the Redneck
hey bis, do you have those measurements?? thanks sswj
03-17-2005, 09:38 AM | #8 | |
03-14-2005, 11:39 PM | #9 |
Embrace the Redneck
oh yea. thanks sswj
03-15-2005, 03:18 PM | #10 |
Embrace the Redneck
ttt
03-17-2005, 10:05 AM | #11 |
Embrace the Redneck
thanks.
just keep in mind that you've got to take your truck out of commission in order to make iy better some times sswj
03-17-2005, 10:17 AM | #12 |
I have roughly 78 inches from tip of yoke to rear of shaft,Sound right,Corse 3 spd spline too. Let me know Let me get a pic of it right fast.
03-17-2005, 10:26 AM | #13 |
pics,snow is free!!!
03-17-2005, 10:33 AM | #14 |
Embrace the Redneck
that's the same measurements that i have now. except i've got 77.5 from center of rear joint to tip of yolk.
That one won't work but i may need that yolk though. keep me in mind. thanks, thanks alot. sswj
03-17-2005, 11:38 AM | #15 |
Embrace the Redneck
TTT. still need a drive shaft that's about 6 inches longer than the one i have.
thanks. sswj
03-17-2005, 12:14 PM | #16 |
Do you by chance have the 3 speed bolted by the tailhousing to an automatic crossmember?
03-17-2005, 08:11 PM | #17 |
Embrace the Redneck
not that i know of. the person i bought the truck from had a 327 with a Munice 4 speed in it but pulled that out and i then bought the truck.
sswj
03-17-2005, 08:41 PM | #18 |
Does it have an alumn.bell housing? All trucks 67-72 used the cast iron bellhousing that bolts to the manual crossmember on the bottom with 2 bolts. I think thats the problem you are having. The only driveshaft that is longer is off a longhorn...
03-17-2005, 08:57 PM | #19 |
Embrace the Redneck
it has a cast iron bellhousing. the pickup had a 327 and a munice 4 spd in it. how's it possiable? help please??
03-17-2005, 09:05 PM | #20 |
Are your motor stands in the front holes or the rear set of holes? If they are in the front holes,they are more that likely 6 cyl stands. And that would explain the 4 inch difference you need? Just trying to help you figure this out,Erick
