03-15-2005, 06:17 PM | #1 |
In Progress
grounds
does anyone have pics of where the chassis grounds should be or could take some pics? and where could i get the ground straps? any help would be greatly appreciated.
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd |
03-15-2005, 06:59 PM | #2 |
Robert Olson Transport
most auto parts stores have the braided steel lines for the grounds with the fittings
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
03-15-2005, 07:17 PM | #3 |
In Progress
would you happen to know where they go on the truck?
03-15-2005, 08:15 PM | #4 |
Placement is not that important, and you can never have to many. Just run one from the frame to the engine block (near the fuel pump works well) from the rear of the engine to the fire-wall (use a bolt screwed into an accessory hole on the back of the head), and one from the frame to the radiator support. While you are at it run one from the frame to the bed (near the rear bumper by the wiring harness) and check the ground wire on your fuel tank. Connect the negative battery cable to the engine block.
03-15-2005, 08:29 PM | #5 |
In Progress
thanks for the help, hopefully this will help fix some of my electrical problems
