06-04-2002, 05:40 PM | #1 |
Engine decoding. What a pain...
Last night I made my third attempt at finding codes on my engine (350-not original).
I found the casting number on back part of the driver's side behind the head (3970010, or something like that), which tells me it's a 2 or 4 bolt main 350 between '69 and '80. Yippie. I already knew that. ...but I haven't been able to find much else, and climbing around on top of the motor is getting old quick. I checked all along the block where the heads attach to see if anything is stamped in the block, but there's nothing there. I also looked behind the passenger side head and found a couple of casting symbols (an "S" I think), plus what may be a three number code but that's about it. My goal here is to find out WHERE this engine came from. The more I work on it the bigger the mystery. Can anyone clue me in as to where information would be to help me solve this puzzle?
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
06-04-2002, 05:43 PM | #2 |
Just Another Crazy Canuck
on hte block on passenger side in the front of the head but if it has ever been decked it might be gone
1985 454/465/205, 38.5x11-16BOGGERS soon to be installed: 14bDETROIT,Edelbrock Performer cam,intake and valve springs,Comp roller tips,MSD HEI |
06-04-2002, 05:46 PM | #3 |
That'll put it right behind my alternator (not original accessories either). That means I'll have to pull the alternator just to get a peak.
Lovely. Anyone else have any ideas?
06-04-2002, 05:52 PM | #4 |
no you dont.,,,,,,
all you need is a flashlight a rag and a long flat screwdriver, first scrape off the pad flat surface real clean with driver then stick rag on end of it and wipe it off and then use flashlight to get the last three letters of the code, the larger digits not the little ones under that stick thwe driver up under the alt from the pass side to get to the pad if the code begins with a T then it should be a 4 bolt, if you have 350 listed on glovebox door then chances are its original engine, but alternator and stuff is not original set up from sounds of it, so maybe engine has been swapped after all easycake Last edited by Fast68Chevy; 06-04-2002 at 05:54 PM. |
06-04-2002, 06:07 PM | #5 |
I'm going to need patience. I'll try again tonight...
06-04-2002, 07:11 PM | #6 |
Psycho-billy Member
Look where the white arrow is....under the head. That is where you will find the numbers.
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). |
06-05-2002, 01:51 AM | #7 |
I GOT THE CODES!!!!!
I found them! Here they are.
V0327TDR - thin big letters outlined in blue (nearest to block) C8Z172910 - smaller deeper letters (below the first set) My code books say "TDR" is either a 1972 K10 & 20, or 1980 C-10 & 1500 series truck. Can anyone confirm/deny this? What about the other numbers?
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. Last edited by COBALT; 06-05-2002 at 01:54 AM. |
06-05-2002, 07:32 AM | #8 |
1969 Custom 30 wrecker
Mad Mikes suffix code chart agrees with that. Either a 1972 or 1980 350. Definetly a truck engine. Whenever there is a "T", it's a truck engine.
The other group of numbers should be build plant, year and part of the VIN from the original vehicle. Im not up on these so someone else might be able to help there.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
06-05-2002, 07:35 AM | #9 |
I'm gonna say that it is the 1980 engine since they did not put VIN numbers on truck engines in 1972.
Tim |
