hi all,,i'm rebuilding a 1976 K-10 stepside. MY question is i bought a 1978 cab that was only a 2 wheel drive so it has the small hump,underneath the truck in the hump is what appears to be like a cut out all the way around,it appears as though it would be the correct cut out for a 4 wheel drive,kinda like when the cabs were made they could be used for either 4 or 2 wheel. DOES anyone know anything about this or may have done it before..thank you all for any help..
I swapped a '78 2X auto cab onto my '73. The '73 is a stick, so I had to cut out the floor on the '78, and used the hump from the '73. The hump on your 4X should unbolt from the floor. I used 1/4" sheetmetal screws to attach the hump to the '78, with a little seam sealer. Been like that for 10 years with no problems....
Wise man once told me; "Don't show me what you know, show me what you don't know" Nothing worthwhile is ever easy Present Stable: 73 C-30 CrewCab Dually 4X2 91 4X2 'burban 89 4X4 'burban 84 4x2 'burban (R.I.P.) |
cover
the cover on the 4x4 floor hump unbolts but on the 2 wheel drive,78 cab there is no cover to unbolt,it is just a "short hump" but stamped into the hump of the 78 2 wheel drive cab is a cut out ,or what looks like a cut out i thought may be for a 4x4 ? thanks to all
![]() i will try to take some pic's tommorrow of what i am talking about. ![]() Last edited by us111; 03-21-2005 at 09:24 PM. Reason: needed to add something |
cut out
here are the pics of the 2 wheel drive cab hump i am talking about,it appears if you follow these lines it would be correct for 4 wheel drive?? thank you
Gentleman Jim Driver
There are at least three different cab floors used on these trucks. 2wd autos have a short hump that doesn't unbolt. 4x4 autos have a tall hump that doesn't unbolt. Manual trans trucks have a hump that unbolts. I've heard others say that they had a factory auto truck with a trans hump that unbolted.
You can use the 2wd cab by modifying it in the trans hump area or using a 2" body lift.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
Yup, IIRC all you have to do is cut on the line.
I remember that I actually used the hump as a template to drill holes, then I used "U" nuts and the factory bolts to secure the hump to the floor as the original tunnel had welded in nuts.
floor
thank you hemikiller,thought it was,wanted to make sure,my old cab (the 4x4) has the nut's welded underneath also,,so sounds like the same deal,,again thanks for the help.....
