Old 03-23-2005, 10:55 AM   #1
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
tilt column / delay wiper control 84 vs 87
Is there any difference in the delay module for 84 and 87 columns? The one in my 84 messed up and the steering shaft that holds the steering wheel wobbles all over. It has the delay wiper and cruise control and all that. So I'm picking up another column that is out of an 87. Wondering what differences I'm going to run into with having everything work correctly?
I know the wiper motors are different and the washer pumps are separate 84 vs 87.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-23-2005, 10:57 AM   #2
beaterC10
The 87 column should be plug and play. I have an 86 Burb column in my 84 with intermittent wipers.
beaterC10 is offline   Reply With Quote
Old 03-23-2005, 11:12 AM   #3
MylilBowTie
Right turn Clyde
The wiper motors being different I wasn't sure if that would cause a problem. I just want everything to work correctly. I can get the other connectors that hook up to the 87 column if I need to.
Old 03-23-2005, 11:20 AM   #4
beaterC10
The connectors should be the same.
