![]() Join Date: Feb 2000
Insulationg and carpeting
Sunday and Monday night I got most of the insulation done on the cab. Laid the carpet in the floor yesterday morning and got out last night to get more done.
![]() ![]() ![]() ![]() These are the 98 Silverado 40/20/40 seats I will be using. ![]() Here are a couple pics of the brackets I am using to mount the seats. My intent was to reinforce the floor to some extent due to the fact that these seats have the integrated seat belts. The mounting holes on these seats do not match the existing holes so what I did was add these plates to the top of the floor and then I have also made three plates that go under the floor. ![]() There is a section of C channel welded to the front bracket that the middle seat attaches to. ![]() ![]() Underneath the truck I have this plate that is in the raised area below the front bracket. ![]() Then I have two additional plates that both go perpendicular to this plate. One is about 5" wide and connects the front seat bracket to the rear seat bracket nearest to the transmission. Then I have a plate that is about 1 1/2" wide that connects the front seat bracket to the rear seat bracket nearest to the door. My intent is that with these brackets tied together from the bottom of the floor to the top of the floor, I have reinforced the floor where the seats bolt in.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 06-24-2010 at 11:09 AM. |
Here are the door panels I made a while back. I finished them in the seat material so that ought to blend well together. Martha Stewart ain't got nothing on me.
![]() I laid the carpet in yesterday morning ![]() Then when I got home last night I got out my new handy dandy box knife and cut out the insulation over the kick panel air vents. A few nights ago I cut a tile backing board to use for carpeting the rear cab wall. I got the carpet glued on that board last night and looks very nice. I considered just gluing the carpet to the back wall but thought a smooth appearance would be better. ![]() I'm not sure how I will secure it. I could get carriage bolts and just use the upper holes that secured the gas tank. However, I think I will try to get some heavy duty velcro or something similar so there is no hardware showing on the carpeted side. For the kick panels I decided not to go with the premade carpet panels. Instead, I bought extra carpet and cut it to fit. I left extra on the bottom and sides so the floor carpet will sit on the excess and make it very seamless. ![]() ![]() For the vent holes I will probably cut the carpet so I can use the excess to flow into the visible portion of the vent hole. Hopefully I can do that and make it look halfway decent. Overall I am very excited with how the carpet is turning out. I have one area on the passenger side near the hump that is bunched up as a result of the firewall modification. Not sure what I will do about that at this time. Probably won't get out to do more work until next week but I am ready to get the seats bolted down. ![]() Here's a last shot as I'm an ![]() ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 06-24-2010 at 11:10 AM. |
71 bb longhorn
Looking good when you put the carpet in was your garage warm ?
71 2500 Gmc longhorn with a 402 turbo 400. 09 F150 Supercrew 4x4 05 Mazda 6 sport accept that somedays you are the statue and somedays you are the pigeon. |
No. The floor carpet is just sitting in there right now - hope to get a warm evening when I actually go to bolting the seats down so I can get the carpet to fit best. Last night was just a test fit of the floor carpet.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
250 V-6 Club
![]() Join Date: Feb 2005
great info. I am also getting ready to install carpet in my 70c/10
1970 Chevy C/10 6 Cyl. 43k original miles all factory ![]() Never ask a stupid question unless you want a stupid answer ![]() |
Man that looks great. Awesome job on the brackets!
Thanks. There has been alot of talk about the safety of using these type of seats in our 67-72 trucks. I can't say that what I have done is the best or sufficient reinforcement so I would recommend that anyone considering these seats with the integrated seatbelts should do some searching in the past threads and decide for yourself whther to use those seats and how to bolt them down.
#8 | |
I have 04 trailblazer seats with integrated seat belts i am planning to put in my 67 and i have the same concerns and plan to make similar brackets to reinforce the floor. My seats will be even more difficult though because the bracket on one side sits about 4" lower than the other and i am having to chanel one side into the cab floor. Your brackets give me some ideas on how to mount mine. Thanks for the pics and post. |
Questionable
I really, really dig the gauge cluster. I mean, everything else seriously kicks ass also, but the dash cluster is the one thing that really screamed out to me when it's contrasted against the paint and carpeting.
How much did you spend on the gauges and where'd you get them? Got any closeup pictures of the gauge cluster?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Active Member
outstanding! Great idea using the backer board to make a smooth appearance- I'll be staeling that idea for my truck in a few days.Hope you don't mind.
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
Here's a pic of the gauges installed.
![]() I got all the gauges from Jeg's and aren't that expensive when you look at their individual price but together you easily wrap up about $450 or so in them ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 06-24-2010 at 11:11 AM. |
Questionable
Sorry to go off-topic again, but do you happen to have the part #'s for the gauges still? I haven't managed to find a thread at the forum yet which gives anything like that...
I used the Phantom series as follows:
Speedo 5895 Oil pressure 5829 Tach 5898 Water temp 5837 Voltmeter 5891 Clock 5885
Questionable
Thanks! Finally, some direction .... Probably going to end up doing them two by two, but anything is better than nothing...
#15 |
Born To Lose Club
![]() Join Date: Feb 2003
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Great Work Yukon! Keep us posted! Great Pics and Info!
Brian Smith ![]() 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
#16 |
Half a bubble off!
Lookin' good Mark! That June deadline is nearing, AGAIN! LOL!
Just call me LB. ![]() '71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads. |
#17 |
Its Magically Delicious
Is that a molded carpet kit ??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
#18 |
Designated A-hole!
Looks good!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
#19 |
resident geek
Lookin gooooood!!
What is the shiny silver stuff you put down before the carpet? Where do you get it and how much is it?
71 C-10 stepper 88 Moostang T-Top w/ lots of goodies |
#20 |
Car O'Holic
wow that is a really clean install nice ++
#21 |
The carpet is molded to fit from Tim Christian. The insulation is from Home Depot and is a foil type insulation. A few other guys here have used it so I thought I would give it a try. I think the name was Reflective Insulation and it is a fairly heavy duty bubble wrap sandwiched between the top and bottom layer of foil. I bought the roll that is 4' wide but I can't remember the length. Seems like it was about $40.00. I will have to see if I have the receipt.
#22 |
resident geek
Does the foil insulation act as a good sound dampner (road noise) or what is the reason for it?
#23 |
It appears it will quiet down the cab but I don't expect it to do the job that products like Brownbread and Dynomat are designed for. This should be better than stock but by no means am I expecting it to be as good as the more expensive products.
#24 |
Questionable
Dynamat and other sound deadeners work on the principle of sticking weight directly to the panel to reduce vibration of the panel. If the shiny stuff in that picture is as light as bubble wrap and it isn't directly adhered to the entire surface of the panel, all it's going to do is block heat, not sound.
I read in another thread where someone got Dynamat or some other type of acoustic matt in a very large amount for around $100.
#25 | |
The LuvShack Garage
IF THAT WAS LAST YEAR IT WAS ME, I SOLD TO LARGE BOXES TO A MEMBER OUT IN CALI FOR A MERE $100 SHIPPED, FUNNY THING IS, I TRIED TO SELL IT ON HERE FOR LIKE A MONTH, NO ONE WANTED IT. ![]() HEY YJ, THAT THING IS BAD A$$, LOOKS REALLY GOOD BUDDY ![]()
