Got big-block?
![]() Join Date: Jul 2000
4/5 drop tire suggestions
For you guys who have this drop, what size tires will work with my 15x8 rally's?
I'd like widest possible out back. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
Garage Queen Material
255/60/15 for the front
275/60/15 for the rear that might give you a little more rake than you would like though |
Ground Pounder
hey
i agree with ocbaud thats what i put on mine on 15x8 ralleys with about a 4/6 drop looks killer although air bags are in the works for it
82 swb ![]() |
Got big-block?
Can you squeeze a 295/50/15 in the rear?
Just wondering.
#5 | |
Slots go on anything!
Casey, I have a pair of 10's with 295/65 Drag Radials on them if you want to try them. I am sure I will be down that way in a couple of weeks or so. They are huge, though.
1974 Jimmy- 5.3/4L80e/NP241 |
Needs a Big Block
Yes indeed you can fit a 295 50 on and 8 inch rally ,
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
driving is in my blood
Not with a good footprint on the pavement though...
I have 255/60's up front and 275/60's out back with a 5-5.5/7 drop and the rake isen't much IMO, but the wheel gap is just right. With only a 4/5 drop you might want a little more tire sidewall to fill in the gap.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
SC, for 8" wheels you can't beat the 275/60 footprint & looks. If you want the fatter 295 or 305, step-up to a 10" wheel. You could squeeze a tire w/the bigger section width on an 8, but it just doesn't look right.
how would a 305 fit on a 15x10 wheel??? also, what would be the widest tire and wheel that i could fit under the rear of my truck with say a 7" drop???
#11 | |
Cruzzzn' Vet
Running 275-50-15's on 15X9 Progressives on a 4/5 drop on my 83 short bed and she looks fine, running 295-50/275-60's on an 8" rim looks like your rollin' on doughnuts
275/60's look really good i think
![]() http://www.ocbaud.com/pictures/truck/truckrain2.JPG |
#14 | |
#15 |
Got big-block?
Well, can you get a 10" rally wheel?
Seems like I got some rallys at the junk yard once off a Suburban that were 9 or 9.5" wide. Guess I'll be heading to the yard to look. SC
#16 | |
#17 |
i have 15X10 truck ralleys that I use at the track with a pair of 28X12.50's. Stockton wheel can build anything you want.
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
#18 |
The ones I have were widened. They have the stock offset to the front, with an additional 2" backspacing.
#19 |
![]() Join Date: Mar 2005
I bought a set of 15x10 Truck Ralleys with a 4.5" backspace from Stockton Wheel and they fit great with a 275/70-15. It's close on the wheel lip, but they don't rub anywhere, even with a 6" drop on the rear.
________ Oregon dispensary Last edited by chevyrestoguy; 02-18-2011 at 10:49 AM. |
#20 |
I have a 4/6 drop . I run 235 60 series 15s on 15x8 rally wheels with a 1" wheel spacer. I have ground off most of the bottom lip on tha a -arm. On sharp turns my truck rubs. the biggest tire I could get on my rallys in the rear 275 60 series
#21 |
Until Seventy Times Seven
Is anyone running or consider running 17" Rallys with their drop? There's a decent selection of tires for 17s to give a similar profile as the 15s. With the correct offset, it may fill the fender wells better without looking too over-powering and hopefully without causing rubbing problems. This may be one way of running 3" drop spindles without grinding the A-arm.
superchevy - What size of dropped spindles are you running? 78chevstepside - Do you have a pic of your lower A-arm?
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
#22 |
I think going to a bigger rim will help out on the rubbing issue.
#23 | |
#24 |
78chev-
Thanks for the pic. I was told that a 16" rim would work on a 3" drop spindle. It may ... barely without any A-arm mod. 17s and up for sure.
#25 |
I have 265/50-15's up front and 295-50/15's in the rear on my 76 stepside.
looks hella fat out back and has a full tire print. I can run a 275-50 15 up front too. My truck is dropped 5 and 5. also has a nice rake to it. I'm not computer savvy so if you want a pic I can email to ya.
My 1st ![]() Owned: 76 chevy suburban 85 chevy K1500 90 chevy C1500 90 chevy K1500 sub 97 chevy C3500 crewcab dually 2000 chevy C3500 crewcab dually ![]() |
