Old 03-27-2005, 11:27 PM   #1
special70gmc
special70gmc's Avatar
heater hose
i shaved my firewall awile back (old pic) and as you can see i just looped the water hose from the heat my question is can i just put pipe plugs in the intake and the water pump or do i keep rockin' the ''ghetto'' loop???
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 03-27-2005, 11:45 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can plug the intake no problem, but I am unsure of plugging the water pump. I kinda suspect that the pressure would build up too much onless you were to drill some fairly large holes in the t-stat.
Old 03-28-2005, 02:47 AM   #3
pjmoreland
pjmoreland's Avatar
My truck has AC. One hose runs from the intake manifold to the heater core. The other hose runs directly from the radiator to the heater core. The hole on the side of the water pump is plugged. I don't see why you couldn't just plug both holes.
pjmoreland is online now   Reply With Quote
Old 03-28-2005, 03:05 AM   #4
70short/step
70short/step's Avatar
You should continue to "loop" it To let the water complete the circulation.
For every person with a spark of genius, There are a hundred with ignition trouble.
70 Short/Step
70short/step is offline   Reply With Quote
Old 03-28-2005, 03:44 AM   #5
RON WOODGEARD
Resident Young Old Dude !
Use the plugged hole on top of the water pump, they make a hose to run from there to the intake.. Then plug the side hole...
But you CAN plug both of the hose outlets/inlets. The circulation is through the Radiator hoses...
I took my heater box out tonight, I had a leak ( solder broke loose)
Man that sure gives a lot more room to work on the passenger side of the engine... It sure is a thought to not put it back on..
So this will be next winters project....
RON WOODGEARD is offline   Reply With Quote
Old 03-28-2005, 03:52 AM   #6
Mudder
Mudder's Avatar
Today I will be changing my heater hoses. The one runs to the radiator now. I'm planning on changing it to the pump. I was told the pump sucks from there and pumps from the intake.????? Hope this works.
Mudder is offline   Reply With Quote
Old 03-28-2005, 10:28 AM   #7
wxman1
Does anybody have a hose # from Napa, A-Zone, Advanced, etc
for a bypass hose for 350 V8s
Jim
Mt Juliet
wxman1 is offline   Reply With Quote
Old 03-28-2005, 11:25 AM   #8
tnblazerk5
User #12137
tnblazerk5's Avatar
plug them the water still goes throw the motor and to the rad and back to the motor !! most of the drag cars/trucks around here are like that ,pluged ,and the t stats sum have drilled holes in them ,sum dont run them, sum run regular ones
tnblazerk5 is offline   Reply With Quote
Old 03-28-2005, 01:53 PM   #9
jhow66
jhow66's Avatar
Plug them-no problems.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
