03-28-2005, 01:47 AM | #1 |
Questionable
Parts cleaner?
This doesn't really fit under engines nor under body work. Not sure what forum to post in, so I'll just stick it here.
What do you guys use to clean the grime off of your engine parts? I want to clean stuff like this tranny crossmember, steering box and other crap, got any suggestions? It's like ... grease + sand caked all over everything:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
03-28-2005, 03:14 AM | #2 |
Life is a gamble
For a running truck, I just take it down to the local self car wash and spray it heavily with degreaser, let it sit for a few minutes, then spray the heck out of it with the sprayer. Of course being careful not to knock any electrical connections.
The underneath is kinda a pain and I always end up wet. So if anyone has any better suggestions, I'm all ears. -ACES
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson |
03-28-2005, 06:34 AM | #3 |
Active Member
Various size putty knives, put some plastic down to help with clean up then to the car wash to get all wet.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin |
03-28-2005, 07:41 AM | #4 |
In a pinch, oven cleaner works just like engine cleaner
03-28-2005, 09:12 AM | #5 |
cleaner
oven cleaner works great. it will take the paint off sometimes if the parts are hot. make sure you have good ventilation when you spray that stuff.
68 SWB Stepside 72 Cheyenne 20 72 SWB Fleetside 72 Suburban 72 2wd Blazer |
03-28-2005, 09:44 AM | #6 |
Never enough time!!
I used a putty knife for the thick stuff, then soaked it with an engine degreaser and let it set for a couple hours, then blasted it off with a pressure washer.....yup, you get soaked too!!
03-28-2005, 10:59 AM | #7 |
cleanup
I use a cleaner called the purple stuff putty knifes and a pressure washer also. my sons truck had it on like cement.Had to use screw drivers and hammers on some pieces.Came out clean.
03-28-2005, 11:04 AM | #8 |
I pulled my I6 drivetrain out...scraped the main grime off with a putty knife...sand-blasted the rest down to pretty metal... blew out the sand with air compressor..painted with chassis saver...put v8 drivetrain in...but this may be a bit on the extreme side...
2004 Corvette Coupe Black LS1 (daily driver) 1973 Ford Bronco (resto/mod @ 95%) 1991 GMC sportside Pickup Truck, 468c.i.d. ('nuff said) 1997 Ford F150 4.2L 500k+ miles (trash hauler) 2011 Nissan Juke (wife's daily driver) 1943 Ford GPW WWII jeep (waiting its' turn) |
03-28-2005, 03:20 PM | #9 | |
Questionable
I'm just curious - they sell a lot of cleaners at the store. I have several boxes of sample-sized grease lightning, but I doubt that stuff is good enough for what I want to do. I also have a few cans of Berryman B-23 laying around, I used those with a wire brush to clean my engine mounts and other stuff when I swapped engines. Just curious to see what other people found useful. It's a messy job, that's for sure.
03-28-2005, 04:26 PM | #10 |
computer illiterate
i like castrol super clean it works great
72 2wd blazer 72 swb 4x4 |
03-28-2005, 04:39 PM | #11 |
I like the oven cleaner route. and you can get the stuff at the 99 cent store. last engine i cleaned up took 5 cans, but it's clean, regasketed, painted up and ready to drop in.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
03-28-2005, 05:15 PM | #12 |
Left Foot Functioning
Regardless of my initial steps, which often include "original" oven cleaner - not the new user-friendly stuff - I use Spray-n-Wash and a good brush for the final cleaning. I find that it removes any residues and washes off well enough to accept paint with no problems.
Also works great on tires. SSOW
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
11-30-2010, 10:54 PM | #13 |
But Found Her 25yrs Later!
Re: Parts cleaner?
I always do a search before posting, and I try to post in the most relevant and newest thread. Most threads talk about steam cleaning or using engine cleaner that requires rinsing with water afterward. My engine has been pulled recently, and I'm taking care of a few of the leaky gasket issues, and I want to clean the grime on the block before putting the parts back on. From searching these forums, I'm leaning toward using kerosene.
Anyone see a problem with this? Thanks
11-30-2010, 11:03 PM | #14 |
computer illiterate
Re: Parts cleaner?
I use kerosene in my parts washer. I have noticed when the kerosene get old and dirty it leaves a residue on the parts so I usually go over them with brake cleaner or mineral spirits before paint.
11-30-2010, 11:10 PM | #15 |
Re: Parts cleaner?
I'm thinking I'll use kerosene, and after I get the engine back together and running, I'll use one of the products where you first warm up the engine, and then rinse with water.
11-30-2010, 11:06 PM | #16 |
Re: Parts cleaner?
leave it on because it'll rust. J/K
I bought a 78 and washed it at the car wash till I had no more beer money, then i washed it at home for three days laying on my back in the driveway with my pressure washer... I ended up taking everything out re-building and fixing leaks then painted... I couldn't stand everytime I worked on the truck having to take my cloths off in the garage before I come into the house. LOL Last edited by fattyarbuckle; 11-30-2010 at 11:07 PM. |
11-30-2010, 11:13 PM | #17 |
Grandpa in the rustmobile...
Re: Parts cleaner?
1 Oven cleaner (use it ventilated, stout stuff!)
2 purple power 3 steam cleaner (pressure washer works ok, but that hot water takes the grease OFF) 4 engine degreaser My favorites are 1 and 3 lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
