03-28-2005, 05:07 PM | #1 |
Spark plug wires and rams horns?
Well after a winter of puttering away on my small block I have it all back together with practically new everything and am faced with what to do for plug wires and routing. I have always hated the under the manifold routing for accessibility and have not as yet ever seen a really nice neat over the top set up. Anybody here have any suggestions as to a particular wire and wire routing set up to get a really nice result?
Saskatoon, Saskatchewan Canada |
03-28-2005, 05:47 PM | #2 |
What was I thinking??
Wires
Like most of us I have used 180deg boots, But just like most of us I don't like the look, Maybe Taylor's 135deg would work better but I have yet to try them.
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
03-28-2005, 05:52 PM | #3 |
That is an amazing familiar picture. The set I have to replace has a multi angle boot and it is a little bit better.
03-28-2005, 06:16 PM | #4 |
With the stock exhaust mainfolds, I think the best way to go is the stock routing. What kind of accessablity do you need? But that's just my opinion....I think it's a lot cleaner look..
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
03-28-2005, 07:06 PM | #5 |
I used 76-85 Big block wires over the top.. And loomed above the valve covers..
03-28-2005, 08:20 PM | #6 | |
Nothing fits but the oil
Land of the free Because of the brave |
03-28-2005, 08:53 PM | #7 |
The oddest Todd around
I used the wires for a 75 corvette 350. They had the ram horns and hei so that wires are the right length (for once).
Todd
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan IIOY??? |
03-31-2005, 01:40 AM | #8 |
How about a picture of the stock 'vette wires with HEI? I'd like to see how they are routed.
03-31-2005, 08:57 AM | #9 |
Here's a picture of my 327 when it was out of my truck. I did a mock-up of my stock wiring.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
03-31-2005, 12:44 PM | #10 |
Thanks Tom. Any chance you got one of the other side?
03-31-2005, 01:02 PM | #11 |
yeah, I used the 75 vette wires, routed like in the pic above... clean and outa sight, never a problem. There's a keeper that comes off one of the pan bolts as shown, and also one at the back of the block as the wires go vertical toward the dizzy.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
03-31-2005, 03:32 PM | #12 |
No sorry I don't have a picture of the other side. I could take some current pictures of the lumis' and such now if needed.
Make sure you use the clips under the ram's horns. Otherwise the wires tend to touch the exhaust manafold and get burned and short out. I know from first hand experience!
03-31-2005, 03:46 PM | #13 |
Relatively new guy to the board with a question about this wiring route.... are the clips and looms available for this somewhere (under manifold route)?
03-31-2005, 06:22 PM | #14 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I picked these up at Pepboys.They're cheap.The heat from the exhaust manifolds has melted 2 of the plastic separators already.The wires are Accell generic's.You have to put them together.The cut to fit kind.All though I didn't need to trim the lengths at all.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
03-31-2005, 10:32 PM | #15 |
Sorry to hijack this thread, but Bobby K, I see you installed a vapor filter on your brake booster vacuum hose. I have the same one, but haven't installed the booster yet. Is there any difference in which ways it goes???
04-01-2005, 12:29 AM | #16 |
Ah...you know it's been a while since I put that on.
I think it IS directional and there should be some kind of marker on it. Sorry I can't give you a better answer.
04-01-2005, 12:52 AM | #17 |
Nope, no directional arrow or any other indications on it. If you blow thru it, it is the same either way. So, I am not sure if it makes a difference. Nothing on the package either.
