04-04-2005, 10:47 AM | #1 |
Temp sensor
I am going to replace my waterpump and starter today. The PO had the temp sensor on the top port of the waterpump. I tried taking the plug off of the drivers side head to use like it should be, but I couldn't get it off. I am going to try again before I give up. Before I go to the auto store, would it be better to still use the port on the waterpump or get one of the water outlets with a port on them. If I use the w/o port, does anybody know off hand which part # to ask for??
04-04-2005, 12:34 PM | #2 |
Cantankerous Geezer
I don't know what engine your running, but most Chevys have to temp sending unit in the head or intake manifold.
Fred There is no such thing as too much cam...just not enough engine. |
04-04-2005, 12:56 PM | #3 |
It is a 350. I couldn't remove the plug on the drivers side head and I am currently using the stock intake and it has no port on there for the water temp sensor or any other port...
04-04-2005, 02:37 PM | #4 |
Questionable
My temp sensor is on the head. The hole in the thermostat housing is plugged on mine.
Here is where the temp gauge sits on mine (note the black wire with the white tip that sits under the orange fuel line for the carb):
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-04-2005 at 02:38 PM. |
04-04-2005, 03:55 PM | #5 |
I know putting a sensor on the head more accurate, but how about the water outlet??? Any opinions??? I'm sure it is better than the water pump.
