ignition lock cylinder problems?
anyone know how to take the ignition lock cylinder out? theres 2 really small holes on it, tried poking a paper clip in there but nothing is happening. thanks
I was told that to get the cylinder out you insert the key and then poke a small wire so something like that it one of the two holes and then the cylinder will pop out. I trie this with my 65 but it would not work. maybe you will have better luck, as mine was very worn out.
Dave 1963 chevy 1/2 ton 4x4 283 4sp. 1962 1/2 ton 292 4sp. 1965 suburban sm.blk. 400 4sp. 3.73 posi. |
Correct, with the key inserted and turned to the on position....insert the paper clip and then turn the key counter clockwise to remove the cylinder. (Be sure the battery is disconnected)
If you have some liquid graphite it would help lube the lock.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
In Section 6Y-51 of the manual, it states "Remove lock cylinder by positioning switch in LOCK position & insert wire in small hole in cylinder face. Push in on wire to depress plunger & continue to turn key counterclockwise until lock cylinder can be removed." What they do not tell you is which hole to stick in the wire. It's the UPPER hole. It's behind that hole that the plunger is located. I use a narrow sharp awl, rather than a piece of wire. Then, it actually comes out! They sure make it difficult.
C10 now is a GMC
Also when reinstalling the key cylinder, have the key in it, and put it back into the hole, and turn right like you are trying to start the engine, and it will automatically lock itself. I just did this on mine last week.
![]() David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod *1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser *1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project |
#6 | |
