Ebay Junky
Column to tranny called Trans Linkage?
i just put in a new column shift steering column, now the part that connects my column to the transmission so i can shift is called trans linkage? and what kind do i need? i have a turbo 400 trans.
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
There is a post a couple of pages back.
Lokar make a awesome setup avaible thru summit.I think it was $40.00 u.s
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
![]() Join Date: Dec 1999
Just bought the Lokar to replace the original linkage to my 700r4. Got it at the Del Mar Goodguys show last week,but haven,t installed it yet! Will do that after the wife tosses it off the coffee table.
Smitty '71 Short Fleetside Spring Valley, Ca. |
I just installed my stock setup. I think I need the lokar setup so I can tuck the exhaust up into the frame rails.
Mario
Ebay Junky
but it is called trans linkage right?
Yepper.
or "transmission shift linkage"
Ebay Junky
is this what i need?
http://store.summitracing.com/defaul...=egnsearch.asp also, what is a kickdown switch?
I guess if you don't have a kick down switch that one at the top of the page would work out for you. I would doubble check with summit to make sure it would work with our app.
Ebay Junky
i dont need a kickdown switch, so i guess that linkage will work? i also need the bracket that bolts to the intake manifold that holds the throttle cable, is this what it looks like?
