Old 04-08-2005, 09:30 PM   #1
Purs
Got Big Block?
Purs's Avatar
Spindles and cut coils
Here is my truck a while back with new stock smallblock springs. Looked pretty high to me, I guess because they were new.... I acquired some McGaughey's drop spindles that I'm going to install with my 5 lug disc brake setup. Before I bought the spindles I cut 1 full coil from the new "original height" coil springs. I've read that will give me about 2" of drop. My question is, what do you guys think my total drop will end up with the 2.5" spindles and these new coil springs with 1 coil cut....?
"Experience is what you get when you didn't get what you wanted."
Purs is offline   Reply With Quote
Old 04-08-2005, 10:00 PM   #2
ratrod67
ratrod67's Avatar
From what I understand cutting 1 coil equals about a 3 inch drop.
ratrod67 is offline   Reply With Quote
Old 04-08-2005, 11:18 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
thats what I got in my first attempt at a home brew drop
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 04-08-2005, 11:26 PM   #4
chopped 71
I CUT ONE COIL FROM THE BLUE TRUCK.
chopped 71 is offline   Reply With Quote
Old 04-08-2005, 11:40 PM   #5
69 longhorn
Yup, 1 coil off the bottom showed me 3" of drop on the old longhorn......your total drop should be 5 1/2" , with a 2 1/2" spindle(well, you can do the math) crazyL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-09-2005, 12:25 AM   #6
Purs
Got Big Block?
Purs's Avatar
yeah, I can do the math, but looking at the pic with the original springs it's hard to believe that cutting one coil would make that much difference.... Oh well, guess I'll start my search for some stock springs.... thanks for the input guys.
Old 04-09-2005, 12:30 AM   #7
5150
C10 Club Tennessee
5150's Avatar
I've heard it's 2 inches, I'm going to do the same thing Purs. My problem is determining if someone has already cut a little of the coil off. I don't want to put my drop spindles on and then have to look for some more stock springs.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-09-2005, 12:44 AM   #8
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
When I cut my springs it gave me about 3"-4" and then 2.5" with spindles so I just went to bags. I was really low static, with no way to lift it up for pebbles
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
