Old 04-10-2005, 03:42 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
a@n fitting's....
When you guys put a@n fuel line together wht do you use to join the pieces plumber's tape?anti siez? putting some new fuel line on the B.B. and need some advise..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 04-10-2005, 03:58 PM   #2
HugrOrang71
Bite me, import boy
HugrOrang71's Avatar
If the fitting is going into a hole with pipe threads, then a small amount of sealant can be used on the threads. If you are talking about AN unions, or installing the fittings on the hose then you shouldn't need any sealant. I usually spray a little WD40 on the hose so that the fittings go into them easier.
Hope this answers your question
Jason
'71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project
"Facts are meaningless, You can use facts to prove anything that's even remotely true."
HugrOrang71 is offline   Reply With Quote
Old 04-10-2005, 04:07 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
I replaced the steel fuel line in the pic with a earls adjustable unit and was wondering if I should use anything at the carb to fuel rail fitting's?? It also has a provision for a fuel pressure guage what should I use there..
MEMBER #6377
Project "7DEUCE"
Old 04-10-2005, 04:11 PM   #4
FRENCHBLUE72
PROJECT 7DEUCE
Whoops heres the pic..
MEMBER #6377
Project "7DEUCE"
Old 04-10-2005, 05:44 PM   #5
john
member #16
john's Avatar
If the new line has inverted flare like the one in pic it is metal to metal, no sealer needed, If the fuel ga. fitting is NPT use should use a sealer. John
john is offline   Reply With Quote
Old 04-10-2005, 06:01 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
Thanks guys for the help....
MEMBER #6377
Project "7DEUCE"
