Old 04-11-2005, 06:57 PM   #1
pappyracing
headlights stopped working
my headlights just quit working, no warning. i changed the switch, dimmer switch, horn relay. i checked all the fuseable links i could find and they are ok. all fuses are good also. any help will be appreciated. thanks
pappyracing is offline   Reply With Quote
Old 04-11-2005, 08:47 PM   #2
griswold510
my taillights did the same....turns out it was a bad ground
griswold510 is offline   Reply With Quote
Old 04-12-2005, 12:18 AM   #3
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Sounds like it could be a bad ground or a loose connection.
Here's a few things to try:
Check the connections at the headlights.
- Check the ground terminal (black wire) with an VOM meter for a good ground.
- Check the other terminal(s) for voltage with a VOM (with the headlight switch in the ON position).
- Check for a solid connection between the headlights and its' connectors.
- Check for good headlights.
Check the terminals at the lightswitch.
- Check the red wire terminal with a VOM (or test light). If no voltage, repair open red wire to battery (fusible link).
- Check the yellow wire terminal with a VOM (or test light). If no voltage, replace light switch.
- Check the yellow wire terminal at the dimmer switch with a VOM (or test light). If no voltage, repair open yellow wire.
- Check the other terminals at the dimmer switch with a VOM (or test light). If no voltage replace dimmer switch.
Check the circuit between the dimmer switch and the headlights.
Good Luck
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 04-13-2005, 08:07 PM   #4
pappyracing
I checked all the grounds i could find and i still have no power to the switch
Old 04-12-2005, 01:00 AM   #5
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah sounds like a bad ground somewhere.
-BoxRodz list most of the places to check.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-13-2005, 03:24 PM   #6
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Mine did just this and its a bad hi/lo switch in the column...that is if your switch is on the column. Fixed mine....then the bastage thieves busted my column.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 04-14-2005, 01:05 AM   #7
boxrodz
boxrodz's Avatar
If you have no voltage to the 'hot' side of the switch, then it sounds like you have an 'open' between the switch and battery. I know you check the fusible links, but it sounds like maybe the fusible link is bad.
boxRODz
Old 04-14-2005, 06:09 PM   #8
pappyracing
I gave up and took it to the garage. Thanks everyone for the help.
Old 04-21-2005, 01:57 AM   #9
boxrodz
boxrodz's Avatar
pappyracing-
Did the shop get your headlight problem resolved? Just curious what the problem was?
boxRODz
