04-15-2005, 12:16 PM | #1 |
Got Big Block?
ECE Brake hose
Anybody know how long the ECE disc brake conversion hose is? You know the one that attaches to the 63-70 hard lines that run along the back of the crossmember? I've got a set off a '78 camaro that have the right fitting size but I'm afraid are too long. If anyone has a pic of some installed I'd appreciate that too.
"Experience is what you get when you didn't get what you wanted." |
04-15-2005, 12:22 PM | #2 |
I just put the ECE disc brake conversion kit on my truck. I'm not sure which "hose" you're talking about. Do you mean the hard line that runs from the front of the prop. valve down to the tee for the front brakes? If so, it should have came with the kit. The only hoses are on the front calipers and the rear end to frame hose.
04-15-2005, 12:25 PM | #3 |
Got Big Block?
I need the length of the rubber hose that attaches to the hard line and goes to the caliper. thanks!
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 04-15-2005 at 12:27 PM. |
04-15-2005, 12:33 PM | #4 |
I have used them off of Camaros before with no problem. Better too long than too short!
04-15-2005, 12:44 PM | #5 |
Got Big Block?
cool. I was just worried about the extra loop. I'll be able to tell more after I mount my wheels (that I haven't bought yet....)
