Old 04-15-2005, 12:38 PM   #1
whitesswj
Embrace the Redneck
whitesswj's Avatar
Front drum adjustment?
Is there a hole on the back side of the brake assembly to do the adjustment or is it only possiable to adjust from the outside (drumside)?
oh, how does the self-adjusters work? I just replaced the shoes, wheel cylinders, and rubber hose on both front brakes.
thanks sswj
'01 Camaro
Son, you just can't get there from here...
whitesswj is offline   Reply With Quote
Old 04-15-2005, 12:43 PM   #2
Only from the outside. I thought that was starnge. Mine was the first vehicle I remember ever accessing the adjuster from the front and not the rear of the drum.
Palf70Step is online now   Reply With Quote
Old 04-15-2005, 02:02 PM   #3
whitesswj
Embrace the Redneck
whitesswj's Avatar
i had a Jeep Comanche where on the rear drums we jacked up put it in neutral and rotated the rear tires and were adjusting the shoes as we spun the tires. that's how i remember how we did it.
SO then how are you supposed to adjust them if you can't even have the tire on??
sswj
'01 Camaro
Old 04-15-2005, 02:09 PM   #4
blazerparts
No,I DON'T have Tourett's
blazerparts's Avatar
Self adjusters, as long as installed right and operable adjust when you stop while backing up. Shoes should be adjusted to just rubbing drums, then backed off one half turn of the star nut. Final adjustment can be made by driving in reverse then applying brakes.........do a couple times.
'72 K5 CST 350/350 Daily Driver
'69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck
'69 GMC 2500 L6292, 3spd beater
blazerparts is offline   Reply With Quote
