04-19-2005, 02:36 PM | #1 |
WTB: Too much to hope for?? 5-lug rear end
What are the chances of someone in North Texas having a 5 lug rear to fit my 67 short bed for around $50?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear Last edited by fade94; 04-19-2005 at 02:45 PM. Reason: Added more info |
04-19-2005, 02:41 PM | #2 |
front or rear
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi |
04-19-2005, 02:45 PM | #3 |
Rear. I edited the post to reflect this also. Thanks for the heads up.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
04-19-2005, 03:09 PM | #4 |
Cowboy Fan for Life!!!!!!
That isn't a crazy price as long as your only requirement is that it's 5 lug. Heck if you were in the Va area, I have 2 or 3 for that price, but they are probably 3.08 single rears.......Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
04-19-2005, 03:49 PM | #5 |
I don't care what the gear ratio is, as long as it can be put under the truck and driven. If only I were closer to VA.... =)
04-20-2005, 09:02 AM | #6 |
Anyone??
04-20-2005, 09:34 AM | #7 |
I have a 5 lug but it has some gear noise. I want more than $50 though. If your interested PM me. I'm in Ft Worth.
04-20-2005, 10:29 AM | #8 |
pm sent
04-20-2005, 11:24 AM | #9 |
Got Big Block?
I've got a good one.... unfortunately it's a 6 lug. I do have a good pair of wheels/tires (pictured) that I'd let go with it.
"Experience is what you get when you didn't get what you wanted." Last edited by Purs; 04-20-2005 at 11:24 AM. |
04-20-2005, 09:15 PM | #10 |
Rear
I have a 1983 5 lug 10 bolt . Gear unknown ,missing one brake drum ( i can look for it . It is a leaf spring rear . You would probably have to modify it to put it in a 67 but it is a FREE rear . I havent looked at a map to see where you are but I am near Bryan ,TX. Frank
04-20-2005, 10:08 PM | #11 |
well i have one but, the diff is welded. i made 3 passes at the drags with it. im located in trenton, about 10min north of you. let me know if you need any other parts
