Old 04-21-2005, 10:04 AM   #1
RICHARD MORGAN
Which internally regulated alternator?
This weekend I plan on converting my externally regulated alternator with an internally regulated unit. I’ve got a lot of good information on how to do it but was wondering which alternator you guys have been using. Any information you guys might have as far part number, make, model, or how many amps it might produce would be very helpful.
Thanks,
RICHARD MORGAN
RICHARD MORGAN is offline   Reply With Quote
Old 04-21-2005, 10:41 AM   #2
Fred T
Cantankerous Geezer
Fred T's Avatar
Easiest swap is to the 10SI or 12SI, which will give you 60-80 amps, depending on the model. When I bought one last year, my local parts store advised against the Delco rebuilds, said the were not lasting. He was having the best results out of the Performance Parts?? brand, said Bosch were almost as good but cost a lot more.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-21-2005, 11:53 AM   #3
vfrdude
vfrdude's Avatar
This should help -
http://www.madelectrical.com/electri...elcoremy.shtml
Rudy Fierros
'95 Honda VFR750F
Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it!
vfrdude is offline   Reply With Quote
Old 04-21-2005, 05:37 PM   #4
nathank
resident geek
nathank's Avatar
I just put a 10SI on my truck, Delco rebuild. Bought it at the parts store for $38. Working good so far!
71 C-10 stepper
88 Moostang T-Top w/ lots of goodies
nathank is offline   Reply With Quote
Old 04-21-2005, 06:15 PM   #5
72BLAZERDUDE
72BLAZERDUDE's Avatar
You can use one from a 85 Pontiac Trans Am. They go up to 108 amp.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 04-21-2005, 06:29 PM   #6
see ten
WTB this ad
see ten's Avatar
That is probably the same alternater that I use from an 84 Corvette which is also a 108 amp. The case is a little larger but as long as you have early style brackets it is no big deal. You will also have to change your plug-in on your wiring harness.
see ten is offline   Reply With Quote
Old 04-21-2005, 06:40 PM   #7
72gord
Never enough time!!
72gord's Avatar
A friend of mine just picked up a single wire alternator from NAPA for under $60, not sure on amp or part number, but he just called and asked about a one wire set up and they said they had one in stock. You just hook up a hot wire, that is it!
72gord is offline   Reply With Quote
Old 04-21-2005, 08:14 PM   #8
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
NAPA P/N 13-4011SW probably.
That's what I have.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 04-21-2005, 10:35 PM   #9
Randy70C-10
Randy70C-10's Avatar
Hey Richard, are you still around? I was just thinking about you today, haven't heard from you in a while.
Randy70C-10 is offline   Reply With Quote
Old 04-22-2005, 06:15 AM   #10
RICHARD MORGAN
Im still around. I've been really busy with the military thing. i'll be leaving for DC on June 1st. I'm just trying to get the truck ready for the long drive. I plan on replacing the fluids, belts, hoses, aand alternator before I leave. I also need to take care of some wiring issues. It looks like i'll be going with an alternator from a 85 Pontiac Trans Am.
Richard
