Old 04-25-2005, 02:24 AM   #1
mapco
tire pressure 18/39.5
I have a set of mickey thomson baja belted on my chevy now they are 18/39.5/16.5. I am wondering what tire pressure people are running these type of tires, mud I am thinking around 15, highway I run 25. Do these numbers sound ok or am I hurting my tires? Any input would be great, thanks...
mapco is offline   Reply With Quote
Old 04-25-2005, 11:05 AM   #2
ryanroo
ryanroo's Avatar
i have 39-15/16.5s and they are on a 9.75 wide wheel. i run 20-22 in them for the street on a 3/4 ton chevy, they get a good foot print that way. it depends on the width of your wheel a little, because a real narrow wheel will pull the sidewalls in and you will have to run lower pressure to let the whole footprint of the tire contact, but then you might have to little air in them and they will get hot going down the road. the thing is the tires will look about the same at 25 psi as they do at 12(i fiddled with mine just for kicks) so you have to keep enough air in the tire to keep it from flexing to much on the road, not so much that you run on the center only and wear them out to fast. so, for your street pressure you will be fine at 25 in my opinion, as for mud, its as low as you can without blowing a bead. good luck
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-25-2005, 12:06 PM   #3
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yeah I run my 39.5x15x16.5 Swamper TSL's at like 22 psi on the street and then just fiddle with them and take a little air out when I got mudding.
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-25-2005, 03:29 PM   #4
Mudder
Mudder's Avatar
I run my 35" swampers at 25 in the front and 22 in the rear for Hwy. Too much air and its all over the road..........
Mudder is offline   Reply With Quote
Old 04-26-2005, 03:20 AM   #5
mapco
well my rims I am running are 12 or 14, been lazy and haven't messured them will do so tomarrow. does it help that much to air down in the mud? I just don't see how airing down would help you out if you are going to risk bead breakage. I can see airing down to a flat tread patch on the dirt or ice more coverage of the imediate traction, but mud seems odd to me. I guess I will have to try different things and see how it works out. Thanks for the hlep..
Old 04-26-2005, 07:33 PM   #6
Hoods69BadBowTie
Chevys Kick A$$
I lower mine a little bit but not to drastically. I put mine a little under 20 psi. I know for rock climbing and sand and other stuff you want to air way down but I don't know why you would way air down for mud either?
-Later
-LATER
Old 05-01-2005, 01:41 AM   #7
ABHaulR
ABHaulR's Avatar
psi
i run 25 on the road and 15 on the sand or mud. oh i have 18x39.5x16.5
boggers.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 05-01-2005, 06:36 AM   #8
LONGHAIR
Beware of running the pressure too low on the street, especially on the front. The natural tilt of the tire/wheel when turning puts more pressure on the lugs on the edges of the tires during sharp turns. This is what wears the tread to make them look like a saw blade, instead of the square that they were made to be. Wider wheels (greater off-set) exaggerate this problem. You need to run just enough pressure to ride to the center tread, slightly holding the edges off of the pavement (when the wheels are straight). The rear can take less, first because it is not carrying as much weight (unladen) and second because they stand straight all of the time. Just remember to adjust the pressure when you rotate the tires.
Another thing that will make them last longer, ride better....and be quieter is to have them "trued". There is usually a "big tire" store in major cities that can do this. You may be surprised at how out-of-round these tires can be.
They are far easier to balance after this too.
LONGHAIR is offline   Reply With Quote
