Rear airbag mount on trailing arms (not stock location)
Just was wondering how some of you guys have the rear bags mounted on the trailing arm, not looking for the stock coil location.
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles |
mines not bagged yet but my buddy's 71 longbed has em mounted further foward and a bridge built across the frame....
49 Chevy - currently under construction being bagged and hunting for a LS drivetrain!!! 09 - Harley nighttrain on air ride! |
soon to be bagged64sub
Thats ^ also what I did, gets pretty good lift. I just drilled a couple of holes in the top of the trailing arms to bolt the bags to.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
I thought about mounting the bags further forward and welding a cross brace on top of the trailing arms so it triangulates the rear without using a panard bar and getting more lift than mounting in stock location.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#5 | |
Mike
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
#6 | |
Seņor Member
I dont understand how it's independent suspension when its a solid rear axle. Corvettes and jags are independent rears. Its hard for me to explain how I would do it without drawing a picture. Just want to clarify not trying to start an argument. OK. Thank you Troy. Even if I kept the track bar I think it could be done without problems with driveshaft clearence or just use a mount that goes on the outside of the frame and mounts to the trailing arms. Just a thought.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 Last edited by shortbed70; 04-29-2005 at 11:51 PM. |
#8 | |
Seņor Member
#9 | |
I bagged my 67 in the rear. I built my own mounts and bridge. I also flipped the trailing arm brackets upside down for better pinion angle. I'll post some pics soon but i get About 26 ins of lift with the front down. And it will lay frame on 20s with a 275/45. i'll post some pics as soon as i get home.
Plus the drive shaft would mostlikely come in contact w/ the cross brace
BK Built
i mounted my bags approx. 8-10" ahead from stock spring perch on my 65 panel, gives great lift(about 19" at rear bumper) while cruizin at a low PSI for a nice ride, and is plenty strong. If i could get my damn panel down here i could get you all pics of the bag mounts, rear notch, and watts-link, but i gotta get it down here to oregon.
I finished my mounts over the weekend so I will try to post some pics tonight
I still need to do a little more but heres where I am at right now
#15 |
Are you going to have to notch the frame where the bag sits so it doesn't rub? I like the look and you should get good lift out of it. What bags are you running?
#16 |
BK Built
Please make sure and gusset and brace the upper bag mounts, if you dont, they will bend way easy.
#17 |
Thanks....there is a 1" clearance between the bag and frame. I am running some contitech bags from *****************. Yeah I still need to do some more work
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles Last edited by DM310; 05-09-2005 at 10:49 PM. |
#18 |
Heres what I did
#19 |
Progress = 0%
Why are you guys trying to get so much lift out of the rear end? Seems like you are putting a lot more stress on the trailing arms the farther forward you move the bag mounts. Just curious.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
#20 |
I only did it that far forward b/c it sits so low and I still have part of my stock frame back there. I did not want my airbags rubbing on the frame
#21 |
BK Built
also, mountin your bags further up on the trailing arms allows you to get the same amount of lift with less air pressure meaning a softer smoother ride at the same height
#22 | |
What kind of bags are you guys running when relocating them forward? What air pressure?
#23 |
I feel the need to make some comments...say what you will to me, but moving the bag up on the trailing arm does not allow you to run less pressure. In fact you will have to run more pressure because the effective spring rate at the axle is decreased as you move the bag up the arm. Effective spring rate (Reff) is calculated as such: Reff = SP x (L1/L2)²; where SP = your spring rate at the bag, L1 = the distance from the trailing arm pivot to the bag (spring), and L2 = the distance from the pivot to the axle centerline. So...Spring Rate has to increase as you move the bag closer to the pivot.
Why not use air-bag over shocks like the shockwaves and mount them directly off of the back of the trailing arms? This would allow you to run low spring rates and actually give you a slight mechanical advantage over the axle.
'68 Chevy Stepside in Frame-up Restoration process. 292 CID Clifford Performance Modified T56 6-speed Tranny Slammed, Custom IFS and IRS Money?...Too Much! |
#24 | |
Progress = 0%
#25 | |
