Old 04-25-2005, 10:41 PM   #1
skokie
skokie's Avatar
Flushing Engine
I am in the middle of a waterpump swap out. What would be a good way to flush out the engine of all of the water and antifreeze?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 04-25-2005, 11:03 PM   #2
jhow66
jhow66's Avatar
Take out the 2 plugs just above the pan rail on each side of block. This will drain the block of all water.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-25-2005, 11:07 PM   #3
skokie
skokie's Avatar
Are you talking about the freee plugs? Can I reuse them?
68 build thread
Old 04-25-2005, 11:39 PM   #4
skokie
skokie's Avatar
When I remove those 2 plugs how fast is it going to come out? Need to know if I need a umbrella
68 build thread
Old 04-25-2005, 11:45 PM   #5
jhow66
jhow66's Avatar
Yeah and don't open your mouth.
Old 04-25-2005, 11:04 PM   #6
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
might have to poke out some rust, but she will flow
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 04-25-2005, 11:11 PM   #7
68w/sbc406
68w/sbc406's Avatar
they are two threaded plugs on each side. not the pressed in freeze plugs
Old 04-25-2005, 11:14 PM   #8
skokie
skokie's Avatar
Ok now I gotcha. So let me ask you this. Once I drain all this out how could I rinse out any litle pieces of junk that is left in the engine? Any suggetions?
68 build thread
Old 04-25-2005, 11:40 PM   #9
Striker169
Car O'Holic
Striker169's Avatar
Fill up the engine again maybe? plug those holes fill radiator with just water crank the engine a couple times to flow the water and flush again? I dono just my 2 cents
Striker169 is offline   Reply With Quote
Old 04-26-2005, 12:55 AM   #10
68w/sbc406
68w/sbc406's Avatar
just leave them open and run a hose in the t-stat housing w/out the t-stat in of course. that should flush stuff out
