Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 04-26-2005, 09:56 AM   #1
68C15
blood type; Retumbo
68C15's Avatar
Question WTB motor mount towers SD
I am gonna get brave & cross the board lines here. I am looking for the metal pieces that go from top of frame to cross member. the motor mount pads bolt to them. according to Longhorn Man this is the item needed to do a Caddy swap.
would the cost & shipping be reasonable or is it best to sneak away from wife/kids & hit the boneyards?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 04-26-2005, 10:08 AM   #2
longhorn71
longhorn71's Avatar
I have a set if you need from a 73-87 truck.20 bucks plus shipping
longhorn71 is offline   Reply With Quote
Old 04-26-2005, 12:25 PM   #3
bigblock73
yeller
bigblock73's Avatar
I have a set too.
Be warned, there are at least two different kinds. I am not sure the exact differences between the two other than their length...but I definately have two different versions...and don't need/can't use one of them.
I can get you dimensions if you like later tonight. JUst trying to save another trucker the grief I already went thru when I purchased mine.
I will sell mine for $20 plus shipping as well.
bigblock73 is offline   Reply With Quote
Old 04-26-2005, 11:14 PM   #4
sdkid
2wd or 4wd? Or does it matter?
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 04-27-2005, 12:55 AM   #5
hotrodmtodd
'Burban Legend
hotrodmtodd's Avatar
Learned From Experience
Here's what I did: Thought it would be cool to drop an Olds in my '76 PU. Used to work for Chevy so I knew that they came with Olds diesels, so I went to the first year they made the Olds' and ordered a set of frame mounts. Well, like BB73 said, somewhere around 78-79 they broadened the frame rails and the mounts I got were like 1-2 inches higher and would not work. So all I did was leave the Cutlass (71) lower mounts on the engine, lowered it down in and scribed some holes to drill with the tranny mount bolted down. I'm sure if you use later model Caddy mounts, there are probably a set of holes in the frame mounts that will lineup. If not, get out your drill and make some new ones. Just consider the whole package before you get carried away. IE: Tranny lines, fan and shroud, etc. Remember that you will be dealing with upper, lower,AND frame mounts. Those new mounts are still sitting on a shelf, but I don't want to insult the rest of the guys with how cheap I would sell them for. Besides, you might not even need them. I wish you luck with your adventure, Hot Rod
hotrodmtodd is offline   Reply With Quote
