04-30-2005, 07:07 AM | #1 |
Axle swap
I thought I read on here a while back that you could just swap out the 6 lug axles for 5 lug axles in a leaf spring 12 bolt. If you can do this, what year truck axle should I look for. Mine is 70 GMC......and has a really sweet "rear", lol, and would hate to change it.
thanks.....
1997 GMC Sierra Ext 1965 Mustang |
04-30-2005, 07:26 AM | #2 |
Designated A-hole!
In the middle of the 70 model year they started using wider rear ends. If yours is the wider rear you should be able to swap 5 lug axles out of 71 and up to 80 or 87 (I can't remember how far it goes). If yours is the earlier (narrower) rear end the axles will be about 3/4 inch too long. I am told you can make spacers to make up for the difference.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
04-30-2005, 07:45 AM | #3 |
Cowboy Fan for Life!!!!!!
Yeah, what Krue said. I had guys tel me that they were direct swaps when I bought a '70 posi rear. Then the axles wouldn't fit and I had to swap the internals..........Jerry
1967 ShortBed Fleetside 3/4 Drop 350/700R4 Tilt wheel 18 x 8 Torque Thrust II's Future mods: All new gauges & wood bed My Zip is 23002 I ship UPS, USPS |
04-30-2005, 08:45 AM | #4 |
So, mid model year or later, assuming that was when my truck was made, I should have the narrow rear. Again, assuming that the rear has never been changed. Is there any place where I could get the specs, length size on those 2 differant rears so I can measure?
thanks......
04-30-2005, 01:40 PM | #5 |
How do you tell when you have the "70 1/2" rear end? Serial #s? Measurements?
This would be good info. Thanks in advance.. Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!" - 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM" - 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL" - 1982 Chev C-10 swb/step 250 I-6 3 spd - - 2001 Chev Silverado LT - |
05-01-2005, 03:04 AM | #6 |
67-70 6 lug is 3/4 of an inch longer on both side then the mid 70-72 I have put 5 lug axels in a 69 you have to space the backing plate out about a 1/2 inch on each side and use the 72 brakes and drums
1998 Pontiac Grad Prix GTP 1969 C10 396 TH400 3.08 posi |
05-01-2005, 10:17 AM | #7 |
What about 77 GMC rear axles??? I have what I THINK is a .308 rear end in my parts truck for the 76 that I dont know what Im going to do with. Would these somehow fit??
05-01-2005, 10:32 AM | #8 |
I learned yesterday, that all truck 12 bolts were the same from mid year '71 thru mid year '81. Then they went to 10 bolt. This according to the "Hollander" manual I was looking thru.......
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 05-01-2005 at 10:34 AM. Reason: mispelling |
05-01-2005, 08:21 PM | #9 |
Bite me, import boy
Why not take some measurements of your axles and have Moser or Dutchman build a set to your specs. Then you get brand new ones (maybe even HD alloys). Or if you have access, have yours redrilled.
Jason '71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project "Facts are meaningless, You can use facts to prove anything that's even remotely true." |
