05-01-2005, 02:25 PM | #1 |
Who's running a 283 in their 60-72?
Whos still running one of these motors? Original? rebuilt? how's the performance? MPG? What are you likes? dislikes? Do you run a std or automatic. let's hear some feedback!
05-01-2005, 02:54 PM | #2 |
GEARHEAD
I am.
I've had it for a while. It's been run with a 3 speed manual, 4 speed manual and a TH-350. It's had a wild cam and an RV cam. MPG varied everytime and depended on the driving habits I had at the time, but anywhere from 10-15 or so. Mostly around 11 or 12 though. It's bored .040", deck and heads are shaved a bit, 1.7:1 roller rockers with screw in studs, headers, stock chevy spreadbore intake with a holley 600 cfm carb. Crane cam and rhodes lifters. It runs good, but due to the lack of cubic inches and a stall converter on the tranny, it's not a tire smoker. But it will easily push the truck over 100 mph. HG
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
05-01-2005, 03:05 PM | #3 |
I've got one in the '69 2wd w/a 4 speed. I like it, but haven't driven it enough to give mileage #'s. I'd expect it to be in the 12-14 range.
I believe it's a mid-60's motor that has been rebuilt w/ stock components. Not a lot of power (2 bbl), but certainly enough for a occasional-use pickup. Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 Last edited by Paul72; 05-01-2005 at 03:06 PM. |
05-01-2005, 05:23 PM | #4 |
I have a 283 that I'll be installing when my truck goes through it's 2nd buildup. It's .60 over, steel crank, milled double hump heads, Duntov cam, Vette ramhorns, trying for a 67 hot rod look. Still need to find either an aftermarket crossram manifold or a 3X2 intake and carbs. I've run 283's in other cras and was pretty happy with them. They are real high winding and peppy if you build them right.
05-01-2005, 07:01 PM | #5 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
I'm running a 283 with no proformance upgades in my '69 K10. It's coupled to a th350...I never really got any accurate gas mileage numbers yet. I like personally like the 283 (tho obiously not original to my Truck). My Truck is a daily driver in the summer and it proforms well enough.
Presently I'm looking for a proper 4 bbl intake for it to run a 4 bbl carb. Presently due to the Pervious Owner it's running a 4bbl carb on a 2 bbl intake with some sorta adapter/spacer to make it work (not well I might add). That is prolly my biggest issue with it thus far.
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
05-01-2005, 07:20 PM | #6 |
I ran 1 .060 over in my old 71. the truck ran an M 21 Muncie, & 3.73 gears.....just a good build & balance on the shortblock, she ran 300 hp 350 heads, & a factory 350 cam, headers/ duals. the old truck would knock down 16.5 to the gallon on the hyway(driven easy) .....those 3.73's eat the fuel , if you wind em up!The old truck had a small4 brl Holley (450 cfm economizer), & really performed well.......just be aware that there is no substitute for cubes......unless its more cubes , or a BLOWER! loook at 383-406.....they will eat some fuel......but man do they run! L
http://community.webshots.com/user/hotrodhorn |
05-01-2005, 08:16 PM | #7 |
I have a original non overhauled 170,000 mile 283 2 bbl from a 67 truck in my 1970 C10 to replace the shot 6 banger. My trans is a 4 speed manual with overdrive and 3.73 gears, 2000 rpm @ 60 mph. Pulls her down the road just fine, but not a racer. Haven't checked mileage, but gas gauge seems to move pretty fast toward empty. Have a liitle blowby and I'm sure a rebulid would give a little more power and mileage. I just might rebuild it just to be different when it needs it. Probably try to find better heads, a performer intake and carb, a small cam around 200 @.050 and headers, HEI, .060 overbore = 292 cubes and she would run sweet I think.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
05-01-2005, 11:12 PM | #8 |
Junior Member
My wife's '63 has a rebuilt 283. It was installed by the P.O. It got about 16 mpg with a two barrel. We put a stock iron 4 barrel manifold with an Edelbrock 600 and factory HEI on it. Not sure of the current milage, the odometer took a crap about ten years ago. It runs great and was a daily driver for years.
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
05-01-2005, 11:38 PM | #9 |
283
thanks for the input. I've got a 67 I've thought of rebuilding, throwing on some 80's 305 heads, mild cam etc. Thought of doing one to be different as well.
05-02-2005, 12:13 AM | #10 |
not trying to be a smart @ss, but dont piss with those 305 heads.....go Fuelie, or Vortec
That old 283 has a lot of potential.......just dont talk to this old man about the old 12/18,or 30/30 cams in those old Vettes......I am old enough to still hear those old boogers running ........damn , did they sound SWEEEEEET! fOR YOU buzzards that dont remember,,,,,,,,,you are too d@mn young.........crazyL
05-02-2005, 12:55 AM | #11 |
283 in mine & I'm lovin it. It was a fairly fresh rebuid by PO, it ran really well when I first bought it with an Edelbrock 2 barrel/Rochester & headers. I've since added an Air Gap intake, Edelbrock 600 cfm carb, headers/proflow's with a 2 1/2" "X" exhaust. I have a HEI (in my closet) and that will be going on next. The thing is a blast to drive, I'm not that speedy of a guy (in my truck) but going through the gears (not WOT or anything) every now & then always creates a .
05-02-2005, 02:11 AM | #12 |
I posted earlier about kind of liking my 283. My only reservation about the 283 is the piston weight. Go to the Kb-silvolite website and do some research. There is plenty of room inside for atleast a 6 in rod and even a 6.25 but nobody makes stock shelf item pistons for that. Now at 1.9 rod/stroke ratio a 283 doesn't really "need" longer rods, but it sure could use lighter pistons, and a longer rod gets you lighter pistons. If I'm going to throw heavier pistons up and down, it just as well be a larger bore, with a higher pin height, hence longer stroke, longer rod too. Any Thoughts anyone.........?????
