Old 05-03-2005, 01:11 PM   #1
bigchevrolet
72 eaton 3/4 full floater axle locker
anyone know who makes a locker for this beast. i have been told to stuff the insides with 14bolt goodies. where is a good place to get these cheap and what all do i need. Diff? axles? bearings? will it fit to the original drums?
bigchevrolet is offline   Reply With Quote
Old 05-03-2005, 03:06 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
This is being considered by a lot of people. Evidently the carriers are the same between the 14 bolt and eaton, so you use the original eaton carrier and 14 bolt detroit, then use the axles from the 14 bolt which are only slightly longer than the eaton and supposedly will fit. or you could find a used eaton w/ detroit and install. got mine for $200 shipped from another board member.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-03-2005, 03:21 PM   #3
bigchevrolet
so all i have to do is buy a detroit locker for a 10.50" 14 bolt and get some axles as well and shove it inside. will the eaton gears bolt onto detroit?
Old 05-03-2005, 03:29 PM   #4
1969 GMC
1969 GMC's Avatar
the eaton and 14 bolt's detroit locker is a lunch box type, it fits inside the stock open carrier and the ring gear bolts to that. they will swap back and forth.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-03-2005, 03:33 PM   #5
bigchevrolet
ok so if thats the case where is the best place to find a detroit lokcer and 14 bolt axles cheap
Old 05-03-2005, 04:30 PM   #6
drink2mny
drink2mny's Avatar
Hey big chev where are you located??
Backbirds can get you new detroit and has 14 bolt axles lying around.
around 350 for detroit and 75 for axles + s&h
Just an option
Support The Board
drink2mny is offline   Reply With Quote
Old 05-03-2005, 09:07 PM   #7
bigchevrolet
i am located in northern minnesota
Old 05-04-2005, 02:16 AM   #8
carryallnut
eaton vs 14 BFF
I'm probably missing something very obvious, but why not just bolt in a 14 bolt with a Detroit locker and be done. They want $150 at our local yards for drum to drum rear axle with the Detroit. You do have to take them out yourself.....and they are heavy.
carryallnut is offline   Reply With Quote
Old 05-04-2005, 03:05 AM   #9
4x4Poet
Part of the obvious part that above. Eaton H052s weigh less than 14bFFs, yet have comparable strength. I've read & heard reports from those who have swapped Eatons for a 14bFF that found the 14bFF made the truck's ride harsher.
Also, one must source a 14bFF from a GM one ton to get the correct wms and spring perch width for a 67-72 GM 4x4. And many folks find Eaton parts cheap.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 05-08-2005, 12:26 PM   #10
carryallnut
14bFF
Also, one must source a 14bFF from a GM one ton to get the correct wms and spring perch width for a 67-72 GM 4x4. And many folks find Eaton parts cheap.[/QUOTE]
I was thinking to just use the axle, and bolt it to the existing springs. Hopefully that would not change the ride quality and keep the mods to a minimum. What are "correct wms", pardon my ignorance.
Old 05-08-2005, 06:56 PM   #11
1969 GMC
1969 GMC's Avatar
They are heavy. I believe in the 450-500 pound neighborhood with the drums attached. I don't know how much lighter the Eaton is, but it is lighter.
The Eaton offers better out of the box ground clearance than the 14 bolt. Both can be shaved for more, but the Eaton will always have the most.
kinda splitting hairs, but I have seen a couple 14 bolts spit the axletubes out of the housing under (severe) load. One in person and a few more at pirate4x4. don't have to worry about that with the Eaton.
1969 GMC K2500
1996 Honda Accord
Old 05-08-2005, 03:57 PM   #12
Americanrider
WMS= Wheel Mounting Surface
Americanrider is offline   Reply With Quote
Old 05-16-2005, 09:26 AM   #13
HeavyK20
HeavyK20's Avatar
big chevrolet,
I have an Eaton that is supposed to have a detroit loker that I would sell. If your'e interested I can take it apart to see what is actually in it.
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
