FS: 68 GMC core support
I could ship this via FEDEX for $120 to your door. It is bulky and will weigh about 50# packaged. I wire brushed and primed the front, top and bottom with some military surplus primer (glossy finish). A little light surface pitting on bottom but no rust through; structurally solid and straight. The back side has some intentionally-done man-made flaws. 1" notches on each side just under upper radiator mounts. 2 tack weld holes where battery tray was welded (needs to be ground down). The bottom right inside lip was bent out . It could be bent back in or left as is. One of the lower radiator mount is loose, but you might want to replace them both with 4 core mounts anyway. I beleive the flaws, even if left alone, won't be visible when installed.
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. Last edited by greenhorn male; 05-03-2005 at 10:30 PM. |
blood type; Retumbo
PM sent
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
67 is sold
Nice piece.
I heard this past weekend, you can use a GMC core support on a Chevy by removeing the headlamp bucket spot welded to the GMC support, is this correct? |
#4 | |
03 Tahoe 72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays. |
