Now the others dig........
![]() Join Date: May 2002
Best Rattle Can Paint?
I posted about painting my interior before...I just wanted to keep it fresh...
I was wondering what the best type of Spray paint from a can is the best brand, the only ones I know of are Krylon, Rust-Oleum, and this SUV, Truck and Van ( thats all I remember from the can) are these recommended? Let me know. Also BODY TAPE?????? Metal tape for body work? let me know!!!
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
Keepin' It Stock
Krylon and Rustoleum are both good brands and I've had good look with both. I like the spray nozzle on Krylon better than Rustoleum - don't get "finger fatique" as bad.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
![]() Join Date: Dec 1999
Depends on what,brackets and pulleys get Krylon,Frame and suspensions get Rustoleum,motors get Duplicolor.I 100% stay away from the 99 cent special crap,2.50 a can for Krylon at WalMart
![]() Join Date: Feb 2001
I like
plastic-kote (cant spell it) seems to last good.
use 3M body tape. Other brands are cheaper, but you pay for it when it comes time to remove it. Also, cheap tape is bad about falling off right in the middle of painting.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Im with mudder, plasti-cote or whatever they call it is best. I use the engine paint for everything and it works very well. They also have the best clearcoat I have seen, very easy to apply with no drips. If you want a really neat paint check out "last blast" LB-1 cast iron paint. Add a little clearcoat over top and it looks just awesome. Think I am going to do some rims like that. The alumiblast by same co is great too.
CoryM
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
Formerly yellow72custom
I have had bad luck with Krylon, it seems to pell off pretty easy when i spray it on something, or maybe i'm just not doing a very good job of cleaning it.....
Plasti-Kote is pretty good paint too. I used some Red Devil spray paint once, and i liked it alot, i just can't seem to find it anymore ![]()
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
You know how many times i rattle restored inside a truck.Im convinced after the last one strip its guts and sand,degrease,sand,prime,and lay it on with a gun,even a $50 cheapy gun.Might take a bit longer but looks better longer,and sanding Rustoleum off your dash in future will suck.
Ditto Rat!
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter ![]() Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain |
A good automotive paint store can put regular automotive paint in a can but it is like 10 bucks a can.
its all about the +6 inches
I think the best paint for small items like motor mounts, brackets, and the like, has to be the little tiny cans of Testors found in the model sections at Wall Mart. This stuff is awsome. The black is beutiful, very durable, and easy to use. The other colors are not quite as easy, but still well worth the effort.
You Think I could get away with using engine enamel.....I painted my hand brake with engine enamel cause I had nothing else....it looks good...and seems to hold well....hmmmmm....maybe.
I just posted a topic about this on the paint and body board. I was looking for interior rattle can paint suggestions for the 72. I like the way the engine enamel from plastic-kote sprays and looks, so i thought i might do the interior with that. But wanted to know if it will hold up.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Jul 2000
I use the Rust-o-leum for underhood brackets, etc., but it takes FOREVER to dry. If my wife's not home, I put the peices in the oven at 300 degrees for an hour, which usually gets the job done. Years ago, I painted an aftermarket A/C bracket with the stuff, and it still looks like new. I hear the Eastwood "chassis black" paint is very good. It's somewhere between gloss and flat and has a high solids content (means it goes a long way).
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#15 |
One more thing -- I always use PPG DX330 wax and grease remover before sanding and then again before painting. Using it before sanding ensures you don't sand wax or grease into the paint. Just make sure you wipe off the residue with a clean rag. Similar stuff is made by Mar-hyde and 3M.
#16 |
I am a Referee of life.
Just did mine in Testors Black and Krylon grey.I like the fact that the Krylon dries fast.I had better luck with the real stuff on tape,I don't remember the brand.I used steel wool to clean the dash and door panels then a degreaser and clean water.I had to do that the second time because I tried to skate the first time and just gloss over with the steel wool.I also used the degreaser and windex on the rubber parts so the tape would adhere better.
The steel wool worked better than sandpapaer because it didn't leave any marks to cover with the paint.Strip the dash because it will look better than if you try to tape it.I also used a light coat of primer on most of it so the peeling wouldn't be such a problem.I did not get pro results but then I have a driver not a show truck. I hope to do a frame offr at some point and really do it right but it looks tons better than it did.Also don't forget to tape up the holes in the dash.That will help make it look more professional than when it has overspray on the wiring ect. under the dash. Every minute you spend taping accurately will pay big dividends when you're finished because it will look much better.Paint can only look as good as the prep work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#17 |
aka Crusher, Crushergmc
Just a note: Plastic-kote is made by the same company that makes House of Color, Valspar (SP). Valspar epoxy primer is great stuff to work with.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
