05-08-2005, 01:15 AM | #1 |
Ram Horn
What size exhust manifolds do I have on my pure stock 72' blazer
with 350 ci.? Will the corvette Ram Horn 2 1/2 inch manifolds fit? Thanks Guys
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
05-08-2005, 07:25 AM | #2 |
Stock truck manifolds are 2"
Yes, the Vette manifolds will work. |
05-08-2005, 07:55 AM | #3 | |
The LuvShack Garage
WITH THE :andy:
05-08-2005, 08:26 AM | #4 | |
Here's a good link for you HatGuy. http://www.castheads.com/corvette_systems.php#manifolds |
05-08-2005, 08:30 AM | #5 |
Thanks so much
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html Last edited by HatGuy; 05-08-2005 at 11:53 AM. |
05-08-2005, 03:14 PM | #6 |
Yea, this is an on oft repeated ?. I ditched the headers on my Jimmy along with the 2 1/4" exhaust. I went back with 2 1/2" 'vette Rams Horns. The 62-63 drivers side was the cheapest I could find and bought two. Used my bandsaw to lop off the generator mounts and a grinder to smooth it out. I used 2 1/2" aluminized pipe and Walker Hemi turbo mufflers. My butt-o-meter says low speed torque is improved and horsepower is at least the same. Mind you I have a little cam, 210/210 @ .050 and .440 lift. This is one of the best mods I have done on the truck and highly recommend it.
05-08-2005, 04:00 PM | #7 |
Thanks Mike,
This is just what I wanted to hear. Where did you get the manifolds? New or used? How Much? $$
05-09-2005, 10:30 PM | #8 |
I think mine came from Eckler's Corvette parts. It was about 5 years ago and they were $75 each new.
05-09-2005, 10:49 PM | #9 |
Mike C,
Thanks again. I luv the board!
05-14-2005, 01:14 PM | #10 |
PROJECT 7DEUCE
Hey joe the last set of ram horn's that I bought was from the local chevy dealer and the were 95 each you may want to try your local dealer first..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-14-2005, 11:26 PM | #11 |
Thanks FB,
I'll check it out at the dealer. See if I can talk em in to a discount.
05-16-2005, 09:08 AM | #12 |
Hey Hat Guy,
FYI once you get your manifolds there is a muffler shop out on the north side called Phil's he is awsome. Al |
05-16-2005, 09:20 PM | #13 |
Real Trucks are Built not Bought Building: 1981 GM SB LowRider 1985 GM K3500 3+3 1981 GM K2500 SSB 1980 GM K2500 X-BC Hydro 1979 GM K3500 3+3 1976 GM K5 Blazer 1970 Custom 10 http://bc4x4.com/ |
05-17-2005, 12:24 AM | #14 |
Thanks Al
Here is more info: http://www.castheads.com/corvette_systems.php http://www.castheads.com/2into1_systems.php anyone tried 2into1 I would like to run a single pipe to the back just like factory exhaust but 2 - 2 1/2" into 3" with nice quite 3" in 3" out freeflow muffler. If there is such a thing.
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html Last edited by HatGuy; 05-17-2005 at 12:26 AM. |
05-17-2005, 08:08 PM | #15 | |
If you are interested, I could email pictures. I can't post them on the board....
Toys: 72 K5 Blazer 74 Vette |
05-18-2005, 01:37 AM | #16 |
Please e-mail pictures to hatguy@hotmail.com
Thanks Skid Could you tell a difference in low end responce? What is the sound like?
05-18-2005, 02:58 PM | #17 |
Compared to the skinny non mandrel bent single exhaust that was on it, the Blazer is making probably 50 more HP. Low end torque is greatly improved as well. It does sound loud with the top on, but I have metal floors currently, so I hear a lot of noise. I went with a huge 3" Dynomax high flow RV muffler because I though it would be quieter, but it is a little loud for my tastes (I don't like to draw attention). I am considering adding a resonator to the exhaust to quieten it down further.
I bought the complete 2-1 system with mandrel bent pipes and gasketless exhaust manifold-pipe interface and have had no issues with leaks etc. I'll email pictures tonight, and you can post them if you want. I'd do it myself but have no host currently.
