Old 05-10-2005, 06:22 PM   #1
Billy G
Billy G's Avatar
Attaching A-Arms
Anyone ever have trouble putting 73-87 bottom A-Arms on a 70 crossmember...getting the pins to line up properly???...that and the same year U-bolts being a little large. I see that the 70's Ubolts are a size smaller....I put the Ubolts in the vise and gently squeezed...took care of that problem....still the alignment pins.
I'd greatly appreciate anyone's feedback in this issue.
Thanks...
Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!"
- 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM"
- 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL"
- 1982 Chev C-10 swb/step 250 I-6 3 spd -
- 2001 Chev Silverado LT -
Billy G is offline   Reply With Quote
Old 05-11-2005, 06:47 AM   #2
Billy G
Billy G's Avatar
ttt
Old 05-11-2005, 07:36 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
I have never done this. but why would you use the later arms with the sloppy rubber bushings? 73-87 ball joints will fit the 70 arms & then you will have more accurate & ridgid suspension.
what I have heard of is using the "saddles" with the larger pins & u-bolts from later. just cut the rivets off & install them on your 70 with some leaf spring center bolts.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-11-2005, 08:15 AM   #4
arkracing
Weekend Warrior
I had a little bit of an issue when doing it - but i used the '69's u-bolts. the pins lined up but it took a bit of cussing and getting pissed.
keep trying man they should go in
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 05-11-2005, 08:55 PM   #5
Billy G
Billy G's Avatar
Got em in...just took the right words....lol....and attitude. Put little floor jack under the arm....lifted the arm into place by hand...then supported. Worked like a champ on the 2nd side.
Thanks for the comments...
Billy G
Old 05-11-2005, 11:04 PM   #6
arkracing
Weekend Warrior
Billy G
See...sometimes you just gotta get mad at it and cuss a little...they eventually cooperate and if not you can always break out the "BFH" (Big F***** Hammer) or the "Firewrench" as i like to call it (oxy/fuel)
-'66 C10 Suburban
