05-11-2005, 10:31 AM | #1 |
Check out GMTrucks.org
WTB 4x4 350 clutch linkage
I'm converting my blazer to manual. I have pedals, but I need everything from there to the clutch fork including the tab that is riveted to frame that holds the z-bar on the frame side.
05-13-2005, 03:02 AM | #2 |
If the stuff off a 3/4 ton 2wd truck is the same. I should have everything you need to put it together. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans. 2001 Chevy ZR2 Ext. cab 4x4 (DD) 1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process) 1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project) |
05-13-2005, 09:54 AM | #3 |
I have everything you need scrubby . I converted my 4x4 to automatic so don't need my manual parts . Hows 40.00 plus the ride . Jose
