Old 05-12-2005, 11:11 AM   #1
farside847
farside847's Avatar
What tools will I need?
I am planning on replacing my rear gear ratio from a 3.73 to a 3.08. I have seen
lots of guys selling the gearsets on the parts forum. But I have never done
this before. What kind of tools will I need? Will I need to press-on anything
or will I need any special removal tool?
I just dont want to get half way through, then figure out I needed a
blue pair of left handed scissors to finish the job...
thanks!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 05-12-2005, 11:16 AM   #2
pjmoreland
pjmoreland's Avatar
The pinion gear bearing is a bit of a chore to get off, but if you are installing a new bearing, then you don't have to worry about it.
pjmoreland is offline   Reply With Quote
Old 05-12-2005, 11:41 AM   #3
cdowns
cdowns's Avatar
i hope you realize that you're going to need a different carrier for the 308gearset. you'll also need a dial indicator to set the gears up
Old 05-12-2005, 11:50 AM   #4
farside847
farside847's Avatar
(blank look)
Ummmm. This was what I was afraid of. Seeing as I dont even know what a
carrier is, nor what a dial indicator even looks like.
Im not afraid of doing something new and learning something along the way,
but to you know of any "how-to" guides that might help me out? I hate to
sound like such an amateur....
Old 05-12-2005, 12:54 PM   #5
JimKshortstep4x4
Talking
I would suggest that you enlist someone to help you that has done a gear set change before. If the gears are not properly meshed you can end up with noisy rear end or the rear end will destroy itself.
Jim
Old 05-12-2005, 01:06 PM   #6
67chevemall
67chevemall's Avatar
Heres my email form a board member! He rocks!
Originally Posted by 67chevemall
It is a stock 12 bolt 3:73 that works great
But the top end is no good.
I would just swap the gears and change the
oil?? What other parts, tools are involved?
What on earth does "the carrier break is 3:42's"
mean?
Cheers and thanks!
BC
The carriers are what the ring gear bolts to. There are different carriers for different gears. There is one for 2:73-2:76, 2:76-3:42,3:42-3:73, and 3:73-up. That's what I mean about breaks.
The gears are not as easy to do as change the gears, chaneg the oil and go. You actually have to "setup" the gears so that the have good connection between the pinion and ring gear. If you were to just take yours off and put mine on and throw them back in you would probably get a noisy diff or possible a broken pinion or ring gear or even a carrier. If you take your parts to a shop they shouldn't charge to much to put it in.
Let me know what you want to do.
So the 3:08's use a different carrier
then my 3:73's? I need 3:08 gears and carrier.
Is it good to "install everything then get it set up.
Or just take all the parts to a good shop?
Cheers
BC
Yes you need a differnt carrier for your 3.08 gears than what you have. I have both the gears and carrier if you want both. And no You need to take the parts to someone to install them for you. it won't work fo you to take it already installed cause they have to take them out again.
They came out of my 73. The gears are nice and smooth, no grooves in them so yes they will work fine in a Daily driven truck
One last ? , What year trucks have the same 12 bolt
rear ends? 67 to ?
Cheers,
67-81.
Hope that helps
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 05-12-2005, 01:05 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
Do you have the factory service manual? If not, it will become the best tool in your toolbox. You can buy a reprint from the on-line parts dealers.
Sounds like you will be over your head on this. I would recommend getting the carrier assembly (pumpkin) out of another truck. That way you don't have to worry about setting up the gears. It will involve only removing the cover, pulling the axles out and changing the carrier. I would also replace the axle seals while you have it apart.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-12-2005, 03:09 PM   #8
flip66
flip66's Avatar
You can get the dial indicator and stand for it at sears in the wood tool department about 85.00 you will need crush sleeve and shims and gear marking compound I got mine a GM dealer. There are allot of articles on the web about how to do it
1998 Pontiac Grad Prix GTP
1969 C10 396 TH400 3.08 posi
flip66 is offline   Reply With Quote
Old 05-12-2005, 06:15 PM   #9
southern parts
southern parts's Avatar
It may be cheaper and easier to find a good used 3.07 rearend and replace the whole thing. Around hear (Atlanta) they sell for about $225.00-$250.00 sometimes less if you can find one at a pull-a-part or pick-n-pull type junkyard.
southern parts is offline   Reply With Quote
Old 05-13-2005, 10:52 AM   #10
farside847
farside847's Avatar
Thanks guys, I hear ya. I will call my mechanic and ask him to refer me to a good
gear shop to do this for me.
Old 05-13-2005, 11:06 AM   #11
Lemield
Lemield's Avatar
Hey farside847,
I was going to do the same thing with a new gearset and an Eaton posi unit for my CST. I know that I am capable of doing it but it is pretty specialized so I called around here in Denver and found a guy that sets them up for a living. He did a wonderful job and he was reasonable. Good Luck.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
