![]() Join Date: Sep 2003
FS - Poly side tanks
I have left and right side tanks (approx 15-16 gal each). The left tank has a small crack on the top of the tank. Tanks come with sending units.
$30 each or $50 for the pair (plus shipping). Paul
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
Not a bad nut after all..
Paul,
How do these tanks mount to the truck? Do they require cutting holes in the box sides for the filler neck? How bad is the crack? Thanks in advance, Wes |
put me inline please, pm me
Thanks, Steve |
Here are some more pics. The tanks were mounted to the bottom of the bed cross-sills with two aluminum straps (similar to gas tank straps) and thru-bolted through the cross sill. There is a hole in the bed side along with a notch in the trim. I thought about re-routing the neck to the front stake pocket, then I decided not to use them. The crack is on the top surface and, ironically, is on the tank that had fuel in it.
Paul
I will take the passenger's side (the non-cracked one). Sending PM...
Pass side sold.
Driver's side $25 to your door. Paul
